I have an haproxy that is a frontend to Redis. Things connect fine, but wen the connection has sat idle for for a minute or so, when you enter the next redis command you get
“server closed the connection” . If I connect directly to the redis this does not happen, please help with suggested haproxy changes that could help
example redis-cli connection - redis-cli -p 7777
example redis-cli direct connection - redis-cli -p 17777
haproxy -vv
HA-Proxy version 1.8.24 2020/02/15
Copyright 2000-2020 Willy Tarreau willy@haproxy.org
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label
OPTIONS = USE_LINUX_TPROXY=1 USE_CRYPT_H=1 USE_GETADDRINFO=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_SYSTEMD=1 USE_PCRE=1
/etc/haproxy/haproxy.cfg
log 127.0.0.1 local1
nbproc 1
nbthread 4
cpu-map auto:1/1-4 0-3
maxconn 40000
timeout connect 5000ms
timeout client 50000ms
timeout server 50000ms
frontend http
bind :8080
default_backend stats
backend stats
stats uri /
stats refresh 10s
stats show-legends
stats admin if TRUE
listen redis7777
bind *:7777
maxconn 40000
balance first
option tcp-check
timeout client 1800s
tcp-check send PING\r\n
tcp-check expect string +PONG
tcp-check send info\ replication\r\n
tcp-check expect string role:master
tcp-check send QUIT\r\n
tcp-check expect string +OK
server REDIS1A 10.1.1:17777 maxconn 20000 check inter 2s
server REDIS1B 10.1.1.2:17777 maxconn 20000 check inter 2s
server REDIS1C 10.1.1.3:17777 maxconn 20000 check inter 2s
