I am configuring HAproxy and would love using with Redis, my configuration is fairly simple:
maxconn 50000
timeout client 30s
timeout server 30s
maxconn 3000
frontend redis
log /dev/log local0 debug
bind *:7899
default_backend redis_servers
server r01 xxx:7899
but when I try to connect to the address with the CLI:
redis-cli -h loadbalancer.test.app -p 7899
I get this log:
Jul 18 15:19:24 lb01 haproxy[114128]: 217.XXX.XX.XXX:279XX [18/Jul/2022:15:19:24.426] redis redis/<NOSRV> -1/-1/0 0 PR 1/1/0/0/0 0/0
I verified and the redis server is working properly, if I execute the same command to connect to it, but with the ip of the machine directly, I can use it with success.
Anyone can help me understand what I am missing?
rhada
July 25, 2022, 2:07pm
#2
you get the response because backend check has failed. You should get an info message in the haproxy logs about this.
Otherwise, if your are sur your redis server is running and accepting requests check ports, firewall, … to see if anything could block requests.
Also, not sure about this but tcp instruction may be in backend section too.
Hope it can helps
Hi.
Use HAProxy in front of some Redis Cluster and everything is working pretty well stable and performant.
Configuration like…
listen Redis_Masters
bind 0.0.0.0:6379
maxconn 512
fullconn 512
timeout client 30s
timeout server 30s
timeout tunnel 12s
option tcp-smart-accept
option tcp-smart-connect
option tcpka
option tcp-check
tcp-check send PING\r\n
tcp-check expect string +PONG
tcp-check send info\ replication\r\n
tcp-check expect string role:master
tcp-check send QUIT\r\n
tcp-check expect string +OK
server REDIS01 xxx.xxx.xxx.101:6379 check port 6379 fall 3 rise 3 on-marked-down shutdown-sessions
server REDIS02 xxx.xxx.xxx.102:6379 check port 6379 fall 3 rise 3 on-marked-down shutdown-sessions
server REDIS03 xxx.xxx.xxx.103:6379 check port 6379 fall 3 rise 3 on-marked-down shutdown-sessions
Hope this can help you find the way.
Greetings,
Pedro
