my haproxy is auto restarted every few minutes, is it by design? from syslog:
Aug 23 04:24:31 localhost haproxy[64543]: [NOTICE] 235/042431 (64543) : New worker #1 (64544) forked
Aug 23 04:24:38 api-lb systemd[1]: haproxy.service: Succeeded.
Aug 23 04:51:11 api-lb systemd[1]: haproxy.service: Main process exited, code=exited, status=137/n/a
Aug 23 04:51:11 api-lb systemd[1]: haproxy.service: Failed with result 'exit-code'.
Aug 23 04:51:11 api-lb systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 1.
Aug 23 04:52:17 api-lb systemd[1]: haproxy.service: Main process exited, code=exited, status=137/n/a
Aug 23 04:52:17 api-lb systemd[1]: haproxy.service: Failed with result 'exit-code'.
Aug 23 04:52:18 api-lb systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 2.
Aug 23 04:56:15 api-lb systemd[1]: haproxy.service: Main process exited, code=exited, status=137/n/a
Aug 23 04:56:15 api-lb systemd[1]: haproxy.service: Failed with result 'exit-code'.
Aug 23 04:56:16 api-lb systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 3.
Aug 23 04:56:36 api-lb systemd[1]: haproxy.service: Main process exited, code=exited, status=137/n/a
Aug 23 04:56:36 api-lb systemd[1]: haproxy.service: Failed with result 'exit-code'.
Aug 23 04:56:36 api-lb systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 4.
Aug 23 04:59:19 api-lb systemd[1]: haproxy.service: Main process exited, code=exited, status=137/n/a
Aug 23 04:59:19 api-lb systemd[1]: haproxy.service: Failed with result 'exit-code'.
Aug 23 04:59:19 api-lb systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 5.
Aug 23 05:00:20 api-lb systemd[1]: haproxy.service: Main process exited, code=exited, status=137/n/a
Aug 23 05:00:20 api-lb systemd[1]: haproxy.service: Failed with result 'exit-code'.
Aug 23 05:00:21 api-lb systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 6.
Aug 23 05:01:15 api-lb systemd[1]: haproxy.service: Main process exited, code=exited, status=137/n/a
Aug 23 05:01:15 api-lb systemd[1]: haproxy.service: Failed with result 'exit-code'.
Aug 23 05:01:15 api-lb systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 7.
Aug 23 05:04:15 api-lb systemd[1]: haproxy.service: Main process exited, code=exited, status=137/n/a
Aug 23 05:04:15 api-lb systemd[1]: haproxy.service: Failed with result 'exit-code'.
Aug 23 05:04:15 api-lb systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 8.
Aug 23 05:05:23 api-lb systemd[1]: haproxy.service: Main process exited, code=exited, status=137/n/a
Aug 23 05:05:23 api-lb systemd[1]: haproxy.service: Failed with result 'exit-code'.
Aug 23 05:05:24 api-lb systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 9.
it’s running under Ubuntu 20.04.1 LTS with HA-Proxy version 2.0.13-2 2020/04/01 - https://haproxy.org/, main config as:
    log /dev/log    local0
    log /dev/log    local1 notice
    maxconn 80000
    mode    http
    option  httplog
    option  dontlognull
        timeout client  50000
        timeout server  50000
    maxconn 80000
systemd file: https://gist.github.com/fayland/5b74c8e75e19291b8143ad14f4fab85e
any thoughts? We just do not want to lose the stats b/c each restart will ease the stats. Thanks
