Jan  7 08:14:52 [xxxx] haproxy[2634]: [WARNING] 006/081452 (2634) : Exiting Master process…
Jan  7 08:14:52 [xxxx] haproxy[2634]: [NOTICE] 006/081452 (2634) : haproxy version is 2.2.5-1ppa1~bionic
Jan  7 08:14:52 [xxxx] haproxy[2634]: [NOTICE] 006/081452 (2634) : path to executable is /usr/sbin/haproxy
Jan  7 08:14:52 [xxxx] haproxy[2634]: [ALERT] 006/081452 (2634) : Current worker #1 (2639) exited with code 143 (Terminated)
Jan  7 08:14:52 [xxxx] haproxy[2634]: [WARNING] 006/081452 (2634) : All workers exited. Exiting… (0)
About every 36-48 hours I’m getting a log entry like this. Somehow its getting a reason to exit and automatically restarts.
Is there a log settings I need to turn on to get debug or other information on this? If I need to update my build or something, no problem.
Thanks in advance!
Fusion
# haproxy -vvv
HA-Proxy version 2.4-dev0-50c03a-40 2020/11/06 - https://haproxy.org/
Status: development branch - not safe for use in production.
Known bugs: Issues · haproxy/haproxy · GitHub
Running on: Linux 4.15.0-111-generic #112-Ubuntu SMP Thu Jul 9 20:32:34 UTC 2020 x86_64
TARGET  = linux-glibc
CPU     = generic
CC      = cc
CFLAGS  = -O2 -g -Wall -Wextra -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
OPTIONS = USE_PCRE=1 USE_OPENSSL=1 USE_LUA=1 USE_ZLIB=1 USE_SYSTEMD=1
Feature list : +EPOLL -KQUEUE +NETFILTER +PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 -CLOSEFROM +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with multi-threading support (MAX_THREADS=64, default=6).
Built with OpenSSL version : OpenSSL 1.1.1  11 Sep 2018
Running on OpenSSL version : OpenSSL 1.1.1  11 Sep 2018
Built with gcc compiler version 7.5.0
(protocols marked as  cannot be specified using ‘proto’ keyword)
h2 : mode=HTTP       side=FE|BE     mux=H2
fcgi : mode=HTTP       side=BE        mux=FCGI
 : mode=HTTP       side=FE|BE     mux=H1
 : mode=TCP        side=FE|BE     mux=PASS
Available services : none
[FCGI] fcgi-app
