Haproxy keeps on crashing
We have two servers both with the same version of Haproxy, the same config file, and the same hardware. However, one server keeps on crashing after a while with:
Oct 30 06:26:39 lb0 haproxy[8951]: [WARNING] 302/062639 (8951) : Exiting Master process...
Oct 30 06:26:39 lb0 haproxy[8951]: [ALERT] 302/062639 (8951) : Current worker #3 (8960) exited with code 143 (Terminated)
Oct 30 06:26:39 lb0 haproxy[8951]: [ALERT] 302/062639 (8951) : Current worker #4 (8961) exited with code 143 (Terminated)
Oct 30 06:26:39 lb0 haproxy[8951]: [ALERT] 302/062639 (8951) : Current worker #2 (8955) exited with code 143 (Terminated)
Oct 30 06:26:39 lb0 haproxy[8951]: [ALERT] 302/062639 (8951) : Current worker #1 (8954) exited with code 143 (Terminated)
Oct 30 06:26:39 lb0 haproxy[8951]: [WARNING] 302/062639 (8951) : All workers exited. Exiting... (0)
Here is the output of server 1:
haproxy -vv
HA-Proxy version 2.0.8-1ppa1~bionic 2019/10/23 - https://haproxy.org/
  TARGET  = linux-glibc
  CPU     = generic
  CC      = gcc
  CFLAGS  = -O2 -g -O2 -fdebug-prefix-map=/build/haproxy-csR09d/haproxy-2.0.8=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-format-truncation -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wno-implicit-fallthrough -Wno-stringop-overflow -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
Built with OpenSSL version : OpenSSL 1.1.1  11 Sep 2018
Running on OpenSSL version : OpenSSL 1.1.1  11 Sep 2018
Built with PCRE2 version : 10.31 2018-02-12
Available services :
	prometheus-exporter
Server 2:
haproxy -vv
  CPU     = generic
  CC      = gcc
	prometheus-exporter
Is there anything I can do to trace the issue? Any pointers are appreciated? Thank you.
For the record, installing 1.8.x works without any issues.
Doesn’t look like a crash. Can you please share the entire output of the log and the dmesg output.
