Trying to config LDAP.
Haproxy version:
[root@gzp-qv-pprod-webapp1 haproxy]# /opt/haproxy/usr/local/sbin/haproxy -v
HA-Proxy version 1.8.21 2019/08/16
Copyright 2000-2019 Willy Tarreau <willy@haproxy.org>
My config:
resolvers ldapdns
nameserver dns1 172.16.6.91:53
nameserver dns2 172.16.6.141:53
nameserver dns3 172.16.1.51:53
nameserver dns4 172.19.12.46:53
accepted_payload_size 8192 # allow larger DNS payloads
listen bl-ldap
bind 127.0.0.1:389
option ldap-check
server-template ldap 5 banglalinkgsm.com:389 check fall 1 rise 1 inter 60s resolvers ldapdns init-addr none
DNS gives 5 ldap servers.
TCP dump shows ldap check success. But haproxy reports LDAP down:
bl-ldap,FRONTEND,,,0,0,3000,0,0,0,0,0,0,,,,,OPEN,,,,,,,,,1,14,0,,,,0,0,0,0,,,,,,,,,,,0,0,0,,,0,0,0,0,,,,,,,,,,,,,,,,,,,,,tcp,,0,0,0,,0,0,
bl-ldap,ldap1,0,0,0,0,,0,0,0,,0,,0,0,0,0,DOWN,1,1,0,1,2,402,402,,1,14,1,,0,,2,0,,0,L7RSP,,10,,,,,,,,,,,0,0,,,,,-1,Not LDAPv3 protocol,,0,0,0,0,,,,Layer7 invalid response,,1,1,0,,,,172.16.1.51:389,,tcp,,,,,,,,
bl-ldap,ldap2,0,0,0,0,,0,0,0,,0,,0,0,0,0,DOWN,1,1,0,1,2,401,401,,1,14,2,,0,,2,0,,0,L7RSP,,2,,,,,,,,,,,0,0,,,,,-1,Not LDAPv3 protocol,,0,0,0,0,,,,Layer7 invalid response,,1,1,0,,,,172.16.6.91:389,,tcp,,,,,,,,
bl-ldap,ldap3,0,0,0,0,,0,0,0,,0,,0,0,0,0,DOWN,1,1,0,1,2,400,400,,1,14,3,,0,,2,0,,0,L7RSP,,1,,,,,,,,,,,0,0,,,,,-1,Not LDAPv3 protocol,,0,0,0,0,,,,Layer7 invalid response,,1,1,0,,,,172.16.6.141:389,,tcp,,,,,,,,
bl-ldap,ldap4,0,0,0,0,,0,0,0,,0,,0,0,0,0,DOWN,1,1,0,1,2,399,399,,1,14,4,,0,,2,0,,0,L7RSP,,10,,,,,,,,,,,0,0,,,,,-1,Not LDAPv3 protocol,,0,0,0,0,,,,Layer7 invalid response,,1,1,0,,,,172.16.1.49:389,,tcp,,,,,,,,
bl-ldap,ldap5,0,0,0,0,,0,0,0,,0,,0,0,0,0,DOWN,1,1,0,1,2,397,397,,1,14,5,,0,,2,0,,0,L7RSP,,2,,,,,,,,,,,0,0,,,,,-1,Not LDAPv3 protocol,,0,0,0,0,,,,Layer7 invalid response,,1,1,0,,,,172.19.12.46:389,,tcp,,,,,,,,
bl-ldap,BACKEND,0,0,0,0,300,0,0,0,0,0,,0,0,0,0,DOWN,0,0,0,,2,397,397,,1,14,0,,0,,1,0,,0,,,,,,,,,,,,,,0,0,0,0,0,0,-1,,,0,0,0,0,,,,,,,,,,,,,,tcp,roundrobin,,,,,,,
TCP dump is attached.
Please help
