Hello!
I’m configuring HAProxy for LDAPs load balancing. Actually I’m replacing old HAProxy which is working well now with the new one.
Old one:
Copyright 2000-2016 Willy Tarreau <willy@haproxy.org>
New one:
HAProxy version 2.4.22-f8e3218 2023/02/14 - https://haproxy.org/
Known bugs: http://www.haproxy.org/bugs/bugs-2.4.22.html
Running on: Linux 3.10.0-1160.90.1.el7.x86_64 #1 SMP Fri Mar 17 08:39:44 UTC 2023 x86_64
Config is pretty simple:
log 127.0.0.1 local2
maxconn 4000
pidfile /var/run/haproxy.pid
ssl-default-server-ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256
stats socket /var/lib/haproxy/stats mode 600 level admin
timeout http-request 1m
timeout queue 1m
timeout client 5m
timeout server 5m
timeout http-keep-alive 10s
timeout check 20s
frontend dap_base_prd_frontend
bind *:636
default_backend dap_base_prd_backend
option socket-stats
option tcpka
option tcpka
option ssl-hello-chk
server dapbaseprd01.dap 172.16.130.4:635 verify none inter 12000 rise 3 fall 3
server dapbaseprd02.dap 172.16.130.6:635 verify none inter 12000 rise 3 fall 3
Old one don’t have different SSL “tuning” parameters like ciphers, but everything else is the same.
If I curl HAProxy locally it works:
curl -v https://dapldapprd.dap:636 --resolve dapldapprd.dap:636:10.195.114.69
* Added dapldapprd.dap:636:10.195.114.69 to DNS cache
* About to connect() to dapldapprd.dap port 636 (#0)
* Trying 10.195.114.69...
* Connected to dapldapprd.dap (10.195.114.69) port 636 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* SSL connection using TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
* Server certificate:
* subject: CN=dapldapprd.dap
* start date: Apr 23 15:37:24 2020 GMT
* expire date: Apr 23 15:37:24 2025 GMT
* common name: dapldapprd.dap
* issuer: CN=Puppet CA: dapmgmtprd01.dap
> GET / HTTP/1.1
> User-Agent: curl/7.29.0
> Host: dapldapprd.dap:636
> Accept: */*
* Empty reply from server
* Connection #0 to host dapldapprd.dap left intact
curl: (52) Empty reply from server
If I do the same curl from any machine inside local network or in another network it reset connection:
CApath: none
* NSS error -5938 (PR_END_OF_FILE_ERROR)
* Encountered end of file
* Closing connection 0
curl: (35) Encountered end of file
What it can be?
Any advice how to debug those things? In the logs I don’t see any errors or even access attempts to LDAP backend.
