HAProxy Configuration for LDAP Loadbalancing
I have 3 LDAP servers which I want HAproxy to loadbalance the connections among them.
Below is my configuration for haproxy.cfg.
I would be very grateful if you share your thoughts and comments.
Thank you for your attention.
[hamed@kafka1 ~]$ sudo cat /etc/haproxy/haproxy.cfg
# Example configuration for a possible web application.  See the
# full configuration options online.
#   http://haproxy.1wt.eu/download/1.4/doc/configuration.txt
# Global settings
    # need to:
    # 1) configure syslog to accept network log events.  This is done
    #    by adding the '-r' option to the SYSLOGD_OPTIONS in
    #    /etc/sysconfig/syslog
    #   file. A line like the following can be added to
    #    local2.*                       /var/log/haproxy.log
    #    log         127.0.0.1 local2
    log         /dev/log local0
    chroot      /var/lib/haproxy
    maxconn     4000
    user        haproxy
    group       haproxy
    # turn on stats unix socket
    mode                    tcp
    option                  tcplog
    retries                 3
    timeout http-request    10s
    timeout queue           1m
    timeout connect         10s
    timeout client          1m
    timeout server          2m
    timeout http-keep-alive 10s
    timeout check           10s
    maxconn                 3000
frontend  main
    bind ipadev.hcp.com:636
#   acl url_static       path_beg       -i /static /images /javascript /stylesheets
#   acl url_static       path_end       -i .jpg .gif .png .css .js
#    use_backend static          if url_static
    default_backend             app
# static backend for serving up images, stylesheets and such
 backend static
    balance     first
    server      static 127.0.0.1:636 check
# round robin balancing between the various backends
backend app
    balance     first
    server  app1 ipadevldap01.hcp.com:636 check
    server  app2 ipadevldap02.hcp.com:636 check
    server  app3 ipadevldap03.hcp.com:636 check```
