Haproxy map backend by domain name not working on https
My config file:
  maxconn 1024
  option  httplog
  option  dontlognull
  timeout client 60s
  timeout server 60s
    bind *:4443
    stats hide-version
    stats uri /stats
frontend rotating_proxies
  bind *:5555
  use_backend ifconfig if { req.hdr(host) -i ifconfig.me }
  use_backend ipinfo if { req.hdr(host) -i ipinfo.io }
  backend ipinfo
    balance leastconn # http://cbonte.github.io/haproxy-dconv/configuration-1.5.html#balance
    server web1 154.85.50.80:5222
    server web2 154.85.70.80:5222
   backend ifconfig
    server web1 154.85.100.80:5222
    server web2 154.85.90.80:5222
I will map backend by incoming domain name, Haproxy should use backend ipinfo if incoming host is ipinfo.io, backend ifconfig if incoming host is ifconfig.me
On http request everything works.
On https side get error proxy aborted.
E.g.
curl -x 127.0.0.1:5555 http://ifconfig.me —> works
curl -x 127.0.0.1:5555 https://ifconfig.me —> Error proxy aborted
If i set default_backend on https side it works but i will map backend by https domain name.
BR
I don’t see any SSL related config in your file. The first thing to do is to configure SSL if you want it to works
