I have configured my HAproxy CE 1.8.19-1+deb10u3 with two backends. To decide which host (req.hdr(host)) belongs to which backend, I use maps, because I can configure them quite easily via REST with Dataplane. But, before I started using haproxy, I already had a lot of vhosts (= subdomains) and if I don’t have to do it, I don’t want to write them all to the map file, just the new ones. Which shouldn’t be a problem, because all my already existing vhosts were configured on one server (= backend), and all new vhosts will be configured either on the same server ( = then don’t create a new map entry) or on the new server ( = then create a new map entry).
So my HAproxy has to look if the called domain (e.g. abc.example.com) is in the map file. If it is, then the backend from the map value should be used. If the host is not in the map file, then a hardcoded backend should be used.
An important point is that when using SSL, the HAproxy should not do an SSL termination (so instead a SSL pass-through) !
Right now I have following configuration (snippet) :
frontend http_in mode http bind *:80 option forwardfor option httplog use_backend %[req.hdr(host),lower,map_str(/etc/haproxy/maps/my_backends.map,http-hardcoded_backend)] # HTTPS Frontend frontend https_in mode tcp bind *:443 option tcplog tcp-request inspect-delay 5s use_backend %[req.hdr(host),lower,map_str(/etc/haproxy/maps/my_backends.map,https-hardcoded_backend)] # == BACKEND - SECTION == # # hardcoded_backend = my old server backend http-hardcoded_backend mode http option forwardfor server OLDSERVER 10.0.150.22:80 backend https-hardcoded_backend mode tcp option ssl-hello-chk server OLDSERVER 10.0.150.22:443 # http(s) backend from map value backend http-mapvalue mode http option forwardfor server MAPVALUE 10.0.150.20:80 backend https-mapvalue mode tcp option ssl-hello-chk server MAPVALUE 10.0.150.20:443
For HTTP, this works (so when I visit a host, which is inside the host file, I get to the “http-mapvalue” backend. When the host is not in the host file, I get to the “http-hardcoded_backend” ), but over HTTPS I get following error message (with cURL):
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to abc.my.domain:443
one both backends.
EDIT:
By adding tcp-request content accept if { req_ssl_hello_type 1 } I get at least requests and therefore logs on my HAproxy. I guess this works now but for some reason, the haproxy doesnt detect the right backend?
[16/Dec/2020:16:09:09.461] https_in https_in/<NOSRV> -1/-1/14 0 SC 1/1/0/0/0 0/0
On HTTP everything works (still) fine, but on HTTPS, which has the same use_backend line it doesn’t.
