I’ve upgraded my version haproxy from 1.8 to 3.0.5 and now i get error on applications “mysql gone away”. I reverted to 1.8 and the error is gone, but with version 3.0.5 get back the error.
One solution is stay with version 1.8 but i want upgrade to 3.0.5 for security issues.
I used haproxy on rocky 8 and the service is used only for mysql (galera)
My configuration:
timeout http-request 10s
timeout queue 5m
timeout client 5m
timeout server 5m
timeout http-keep-alive 10s
timeout check 10s
maxconn 20000
frontend galera
bind x.x.x.x:3306
option tcpka
timeout client 480m
acl ipgalera src -f /etc/haproxy/galera.lst
use_backend galera if ipgalera
default_backend trash
backend galera
timeout server 480m
timeout connect 60s
option external-check
external-check path "/usr/bin:/bin:/usr/local/bin"
external-check command /usr/local/bin/mysql_galera.sh
server g1prod y.y.y.y:3306 check inter 5s fall 2 rise 1
server g2prod z.z.z.z:3306 check inter 5s fall 2 rise 1 backup
Any idea about the problem exist with version 3.0.5 and not with 1.8?
So many things changed between 1.8 and 3.0.x that it’s hard to tell what could cause this timeout to appear after the upgrade.
Can the issue be reproduced easily? I would suggest to try to progressively upgrade from 1.8 to 2.6 then 2.8, to help spot where it first appears. If you could at least make it up to 2.6 without errors, then you would benefit from latest bugfixes as 2.6 will be maintained until Q2-2027 (while waiting to find out why it fails on 3.0)
Sorry for late response.
I’ve checked the log but don’t help anything to find the difference between 1.8 and other versions of haproxy.
My configuration is exactly the same on haproxy between 1.8 and other version.
When put version 2.2 or 2.4 or 3.0.5 i get many errors mysql gone away. With 1.8 (i’ve compiled the last version from 2022), 0 errors.
I’ve mentionned mysql, but with postgresql (patroni), i’ve checked the logs and get the same errors on many applications java try to connect do DB postgresql. With version 1.8, don’t get any errors.
On mysql, many of my application is on apache.
It’s very strange but don’t find any solution or difference
on 1.8, did you use nbproc ? Because back then the total maxconn would be maxconn * nbproc, but with nbthreads this number is shared and must be tuned correctly
When looking at “gone away” errors, do they start to happen rapidly after haproxy is started or it takes a long time after haproxy was started to get the first error, and then other errors keep flowing?
When your applications are saying “mysql is gone”, what is HAproxy saying? Are the defined backends up with your external health-checks?
In your situation, I would try it first without health-checks
