I configured 3 servers to act as proxy for mysql galera cluster.
And this is my haproxy config file on 3 servers.
log 127.0.0.1 local0 notice
# MySQL Load Balance Pool
listen mysql-cluster
bind 0.0.0.0:3306
option mysql-check user haproxy_check
server st-cntrl 10.0.0.101:3306 check weight 1
server st-ctl02 10.0.0.102:3306 check weight 1
server st-ctl03 10.0.0.103:3306 check weight 1
The problem is when I test haproxy with command below, I get handshake error.
mysql -h 127.0.0.1 -u haproxy_root -p -e "SHOW DATABASES"
error:
ERROR 2013 (HY000): Lost connection to MySQL server at 'handshake: reading inital communication packet', system error: 11
BTW mysql and haproxy and keepalived are on same servers.
Both “haproxy_root” and “haproxy_check” are created in mysql and grant permission by commands below.
mysql -u root -p -e "GRANT ALL PRIVILEGES ON *.* TO 'haproxy_root'@'st-XXX'; FLUSH PRIVILEGES"
mysql -u root -p -e "GRANT ALL ON *.* to 'haproxy_check'@'st-XXX';"
What should I do to fix the issue.
Regards,
Mohammad
Read haproxy logs, check the server status.
It’s possible the health checks fails (for whatever reason). Try without the check keyword in the server configuration.
Thanks for reply.
I got these errors with the check keyword.
Dec 30 13:57:56 st-cntrl haproxy[1851]: [WARNING] 363/135641 (1851) : Reexecuting Master process
Dec 30 13:57:56 localhost haproxy[1851]: Proxy mysql-cluster started.
Dec 30 13:57:56 localhost haproxy[20487]: Stopping proxy mysql-cluster in 0 ms.
Dec 30 13:57:56 localhost haproxy[20487]: Proxy mysql-cluster stopped (FE: 158 conns, BE: 158 conns).
Dec 30 13:57:57 localhost haproxy[20657]: Server mysql-cluster/st-ctl03 is DOWN, reason: Layer7 invalid response, check duration: 1ms. 2 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
Dec 30 13:57:58 localhost haproxy[20657]: Server mysql-cluster/st-cntrl is DOWN, reason: Layer7 timeout, check duration: 2001ms. 1 active and 0 backup servers left. 3 sessions active, 0 requeued, 0 remaining in queue.
Dec 30 13:57:58 localhost haproxy[20657]: Server mysql-cluster/st-ctl02 is DOWN, reason: Layer4 timeout, check duration: 2001ms. 0 active and 0 backup servers left. 3 sessions active, 0 requeued, 0 remaining in queue.
Dec 30 13:57:58 localhost haproxy[20657]: proxy mysql-cluster has no server available!
Dec 30 13:58:05 st-cntrl haproxy[1851]: [WARNING] 363/135756 (1851) : Former worker 20487 exited with code 0
And these errors without check keyword.
Dec 30 13:59:12 st-cntrl haproxy[1851]: [WARNING] 363/135756 (1851) : Reexecuting Master process
Dec 30 13:59:12 localhost haproxy[1851]: Proxy mysql-cluster started.
Dec 30 13:59:12 localhost haproxy[20657]: Stopping proxy mysql-cluster in 0 ms.
Dec 30 13:59:12 localhost haproxy[20657]: Proxy mysql-cluster stopped (FE: 192 conns, BE: 192 conns).
Dec 30 13:59:12 st-cntrl haproxy[1851]: [WARNING] 363/135912 (1851) : Former worker 20657 exited with code 0
What could be the problem ?
Maybe you need to specify the post-41 keyword, I assume you have a more recent mysql release?
mysql-check [ user <username> [ post-41 ]
so:
option mysql-check user haproxy_check post-41
https://cbonte.github.io/haproxy-dconv/1.6/configuration.html#4-option%20mysql-check
Not sure why haproxy immediately stops without the checks …
Can you provide the output of haproxy -vv, systemctl status haproxy and uname -a
Yes, I have recent mariadb 10.4.11.
Here is haproxy -vv result:
HA-Proxy version 1.8.8-1ubuntu0.9 2019/12/02
TARGET = linux2628
CC = gcc
CFLAGS = -g -O2 -fdebug-prefix-map=/build/haproxy-O1awHi/haproxy-1.8.8=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2
OPTIONS = USE_GETADDRINFO=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_SYSTEMD=1 USE_PCRE=1 USE_PCRE_JIT=1 USE_NS=1
Built with transparent proxy support using: IP_TRANSPARENT IPV6_TRANSPARENT
IP_FREEBIND
And here is systemctl status haproxy result:
Loaded: loaded (/lib/systemd/system/haproxy.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2019-12-30 12:02:40 +0330; 2h 43min ago
Docs: man:haproxy(1)
Process: 26689 ExecReload=/bin/kill -USR2 $MAINPID (code=exited, status=0/SUCCESS)
Process: 26688 ExecReload=/usr/sbin/haproxy -f $CONFIG -c -q $EXTRAOPTS (code=exited, status=0/SUCCESS)
Process: 1649 ExecStartPre=/usr/sbin/haproxy -f $CONFIG -c -q $EXTRAOPTS (code=exited, status=0/SUCCESS)
Main PID: 1851 (haproxy)
Tasks: 2 (limit: 4915)
├─ 1851 /usr/sbin/haproxy -Ws -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -sf 26525
└─26690 /usr/sbin/haproxy -Ws -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -sf 26525
Dec 30 14:37:07 st-cntrl systemd[1]: Reloaded HAProxy Load Balancer.
Dec 30 14:37:07 st-cntrl haproxy[1851]: [WARNING] 363/143707 (1851) : Former worker 25672 exited with code 0
Dec 30 14:42:17 st-cntrl systemd[1]: Reloading HAProxy Load Balancer.
Dec 30 14:42:17 st-cntrl systemd[1]: Reloaded HAProxy Load Balancer.
Dec 30 14:42:17 st-cntrl haproxy[1851]: [WARNING] 363/143707 (1851) : Reexecuting Master process
Dec 30 14:42:26 st-cntrl haproxy[1851]: [WARNING] 363/144217 (1851) : Former worker 25818 exited with code 0
Dec 30 14:43:19 st-cntrl systemd[1]: Reloading HAProxy Load Balancer.
Dec 30 14:43:19 st-cntrl haproxy[1851]: [WARNING] 363/144217 (1851) : Reexecuting Master process
Dec 30 14:43:19 st-cntrl systemd[1]: Reloaded HAProxy Load Balancer.
Dec 30 14:43:19 st-cntrl haproxy[1851]: [WARNING] 363/144319 (1851) : Former worker 26525 exited with code 0
And here is ‘uname -a’ result:
Linux st-cntrl 4.15.0-72-generic #81-Ubuntu SMP Tue Nov 26 12:20:02 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
Did you try with post-41?
Yes, I did.
Now I’ve got serious problem. Mysql service won’t start.
This is with haproxy service started:
root@st-cntrl:~# service mysql start
Job for mariadb.service failed because the control process exited with error code.
See "systemctl status mariadb.service" and "journalctl -xe" for details.
root@st-cntrl:~# systemctl status mariadb.service
● mariadb.service - MariaDB 10.4.11 database server
Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/mariadb.service.d
└─migrated-from-my.cnf-settings.conf
Active: failed (Result: exit-code) since Mon 2019-12-30 18:02:44 +0330; 3s ago
Docs: man:mysqld(8)
https://mariadb.com/kb/en/library/systemd/
Process: 15651 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=exited, status=1/FAILURE)
Process: 16548 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=`/usr/bin/galera_recovery`; [ $? -eq 0 ] && systemctl set-environment _WSREP_START_
Process: 16539 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 16531 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
Main PID: 15651 (code=exited, status=1/FAILURE)
Dec 30 18:02:44 st-cntrl mysqld[16548]: 2019-12-30 18:02:42 0 [Note] InnoDB: 10.4.11 started; log sequence number 1583550091; transaction id 18045557
Dec 30 18:02:44 st-cntrl mysqld[16548]: 2019-12-30 18:02:42 0 [Warning] InnoDB: Skipping buffer pool dump/restore during wsrep recovery.
Dec 30 18:02:44 st-cntrl mysqld[16548]: 2019-12-30 18:02:42 0 [Note] Plugin 'FEEDBACK' is disabled.
Dec 30 18:02:44 st-cntrl mysqld[16548]: 2019-12-30 18:02:42 0 [Note] Server socket created on IP: '10.0.0.101'.
Dec 30 18:02:44 st-cntrl mysqld[16548]: 2019-12-30 18:02:42 0 [ERROR] Can't start server: Bind on TCP/IP port. Got error: 98: Address already in use
Dec 30 18:02:44 st-cntrl mysqld[16548]: 2019-12-30 18:02:42 0 [ERROR] Do you already have another mysqld server running on port: 3306 ?
Dec 30 18:02:44 st-cntrl mysqld[16548]: 2019-12-30 18:02:42 0 [ERROR] Aborting'
Dec 30 18:02:44 st-cntrl systemd[1]: mariadb.service: Control process exited, code=exited status=1
Dec 30 18:02:44 st-cntrl systemd[1]: mariadb.service: Failed with result 'exit-code'.
Dec 30 18:02:44 st-cntrl systemd[1]: Failed to start MariaDB 10.4.11 database server.
And this is with haproxy and keepalived service stoped:
Active: failed (Result: exit-code) since Mon 2019-12-30 18:11:03 +0330; 5s ago
Docs: man:mysqld(8)
Process: 17535 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=exited, status=1/FAILURE)
Process: 17368 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=`/usr/bin/galera_recovery`; [ $? -eq 0 ] && systemctl set-environment _WSREP_START_
Process: 17359 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 17351 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
Main PID: 17535 (code=exited, status=1/FAILURE)
Status: "MariaDB server is down"
Dec 30 18:10:27 st-cntrl systemd[1]: Starting MariaDB 10.4.11 database server...
Dec 30 18:10:30 st-cntrl mysqld[17368]: WSREP: Recovered position f1e2d4b2-261e-11ea-9fb6-0f1225d0af82:345327
Dec 30 18:10:30 st-cntrl mysqld[17535]: 2019-12-30 18:10:30 0 [Note] /usr/sbin/mysqld (mysqld 10.4.11-MariaDB-1:10.4.11+maria~bionic) starting as process 17535 ...
Dec 30 18:11:03 st-cntrl systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Dec 30 18:11:03 st-cntrl systemd[1]: mariadb.service: Failed with result 'exit-code'.
Dec 30 18:11:03 st-cntrl systemd[1]: Failed to start MariaDB 10.4.11 database server.
Well you cannot have one the same machine listening to port 3306 both mysql and haproxy. Either one of the other. Decide.
Ok, I got everything’s right.
I installed HAproxy on two separate nodes and three mysql server on there other node.
My first question Is, does this architecture correct ?
And my second question is I want to know where did I configured wrong that I give “Access denied” error from my second HAproxy server. I granted access to mysql.
root@st-hap01:~# mysql -h 127.0.0.1 -u haproxy_root -p -e "show variables like 'server_id'"
Enter password:
| Variable_name | Value |
| server_id | 1 |
Enter password:
ERROR 1045 (28000): Access denied for user 'haproxy_root'@'10.0.0.99' (using password: YES)
And this is mysql users:
MariaDB [(none)]> select user,host,password from mysql.user;
| User | Host | Password |
| haproxy_check | 10.0.0.99 | *7FCFF8A4388C0668B95E75D920D31480B709E916 |
| haproxy_check | 10.0.0.98 | *7FCFF8A4388C0668B95E75D920D31480B709E916 |
| haproxy_root | 10.0.0.99 | *60E34B079D38AC45EAAF0B43817E3938A96619AD |
| haproxy_root | 10.0.0.98 | *60E34B079D38AC45EAAF0B43817E3938A96619AD |
You see that passwords are the same.
And my haproxy.conf from two HAproxy servers:
maxconn 4096
timeout queue 1m
timeout client 1m
timeout server 1m
timeout check 5s
bind 127.0.0.1:3306
Regards,
Mohammad
My problem solved.
It was Galera cluster nodes disconnected from cluster.
