dear all,
i am configuring haproxy and keeplived and mysql server on same physical machine. but my load balancing is not working. request getting on mysql 1 server only. i am using the keeplived ip for requesting.
Can you show your haproxy configuration? That’ll make it easier to give specific help!
25 add-apt-repository ppa:vbernat/haproxy-1.6
26 apt-get update
27 apt-get install haproxy -y
28 cp /etc/haproxy/haproxy.cfg /etc/haproxy/haproxy.cfg.original
30 /etc/init.d/haproxy start
31 vim /etc/default/haproxy
32 vim /etc/haproxy/haproxy.cfg
listen mysql-galera-cluster 0.0.0.0:3307
#balance roundrobin
option tcpka
option mysql-check user haproxy
server mdb1.example.com 192.168.25.87:3306 check weight 1
server mdb2.example.com 192.168.25.88:3306 check weight 1
On the client, are you connecting towards the default mysql port 3306 or the TCP port you configured the load-balancer on, which is 3307?
