Am using haproxy and keealived in my project but nothing is working.
All services are UP but web app isn’t working.
Please find bellow haproxy.conf:
frontend avfanew
bind 10.5.123.69:80
bind 10.5.123.69:443 ssl crt /etc/ssl/certs/myssl.pem
acl host_servic hdr(host) -i avfa-servic.app.com
use_backend servic_cluster if host_servic
acl host_matser hdr(host) -i master.app.com
use_backend master_cluster if host_matser
#mode tcp
#stats enable
#stats auth admin:123
#server Web01 10.5.123.4:80 check
server web01 10.5.123.6:80 check
#mode tcp
#stats enable
server web02 10.5.123.4:443 check
keepalived.conf:
virtual_server 10.5.123.69 80 {
delay_loop 4
#lb_algo rr|wrr|lc|wlc|sh|dh|lblc
#lb_algo wrr
#lb_kind NAT|DR|TUN
lb_kind DR
persistence_timeout 60
#protocol TCP|UDP
protocol TCP
# Server to be added to the pool if all real servers are down
#sorry_server @IP PORT
real_server 10.5.123.4 443 {
    weight 1
    TCP_CHECK {
        connect_timeout 60
        connect_port 443
delay_loop 4
#lb_algo wrr
#lb_kind NAT|DR|TUN
lb_kind DR
#protocol TCP|UDP
protocol TCP
real_server 10.5.123.6 80 {
    weight 1
    TCP_CHECK {
        connect_timeout 60
        connect_port 80
