I am new to HAproxy. I am trying to implement below but its not working, I want to use 3 ips, each for HAproxy servers and one for VIP. Configure /etc/hosts file so that test.com will point to VIP. Want to make 2 HAproxy servers to work in master slave HA mode using keepalived. Create self sing cert for haproxy. configure backend server of these HAProxy servers to be www.google.com if i hit https://test.com in local browser it should show the contents of google.com, it should be just proxy to google.com, url on the browser should remain https://test.com while showing google.com
I have installed haproxy,keepalived on centos7 master and slave servers with below configuration
In /etc/haproxy/haproxy.cfg file on master server,
frontend  main *:80
use_backend static if url_static
default_backend             app
backend app
http-request set-header Host www.google.com
server site google.com:443 ssl verify none check
In /etc/keepalived/keepalived.conf,
vrrp_script chk_haproxy {
script “killall -0 haproxy” # check the haproxy process
interval 2 # every 2 seconds
weight 2 # add 2 points if OK
vrrp_instance VI_1 {
interface eth1
state MASTER
virtual_router_id 51
priority 101
virtual_ipaddress {
172.28.128.33
track_script {
chk_haproxy
/etc/hosts - 172.28.128.33 test.com
If i try elinks https://test.com i get unable to retrieve https://test.com Connection refused.
Please note, i have not configured self sign certificate yet.
Can someone please help. Thanks
