HAproxy with Lets encrypt
Hello
I have searched the forums and found many similar questions but nothing that solves this.
I have 2 webservers (apache) and HAproxy as LB in conjunction with keepalived. We use ISPconfig to manage and create websites. We use a VIP for load balancing. ISPconfig is set so that web-02 is a mirror of web-01.
When we point the public address directly to web-01 we can create certs just fine via ISPconfig. But for LB we need it to point to the VIP and it doesn’t work. I’m testing this with some dry runs with certbot and I can create certs via web-01 but not via web-02. Let me know if you need more info.Here is the haproxy config:
frontend http
bind *:443
default_backend web.kh.vbm.se
stick-table type ip size 200k expire 30m
stick on src
option ssl-hello-chk
server web-01 192.168.11.100:443 check
server web-02 192.168.11.101:443 check
