HAProxy / Keepalived not forwarding traffic
Hi All,
I am really new to HAProxy and Keepalived its been a steep learning curve this week, but I think I am almost at my end goal and my suspicion is that I am missing a really simple step to achieve what I need to. I would really appreciate any help someone could give me.
THe issue I am having is that the load balancer does not appear to be forwarding traffic to the backends when using the VIP. I can ping the VIP so I know its up.
I was able to perform a curl http://192.168.5.42 command and get the desired response, from the MASTER node itself. However I then in my attempt to resolve the issue added an HAProxy.xml file to the /etc/firewalld/services folder with the below settings and now I cannot perform that command:
<?xml version="1.0" encoding="utf-8"?> HAProxy HAProxy load-balancer
In my lab I have the following setup
2 x RHEL 7.6 servers with HAProxy and Keepalived installed
2 x Windows 2016 IIS servers with default IIS page with bindings on 80
RHEL-A Keepalived setup:
! Configuration File for keepalived
global_defs {
notification_email {
acassen@firewall.loc
failover@firewall.loc
sysadmin@firewall.loc
notification_email_from Alexandre.Cassen@firewall.loc
smtp_server 192.168.200.1
smtp_connect_timeout 30
router_id LVS_DEVEL
vrrp_skip_check_adv_addr
vrrp_strict
vrrp_garp_interval 0
vrrp_gna_interval 0
vrrp_instance VI_1 {
state MASTER
interface ens33
virtual_router_id 51
priority 100
advert_int 1
authentication {
auth_type PASS
auth_pass 1111
virtual_ipaddress {
192.168.5.42 dev ens33 label ens33:100
virtual_server 192.168.5.42 80 {
delay_loop 10
protocol TCP
lb_algo rr
Use direct routing
lb_kind DR
persistence_timeout 7200
real_server 192.168.5.50 80 {
    weight 1
    TCP_CHECK {
      connect_timeout 5
      connect_port 80
real_server 192.168.5.51 80 {
    weight 1
    TCP_CHECK {
      connect_timeout 5
      connect_port 80
RHEL-A HAProxy Setup
Example configuration for a possible web application. See the
full configuration options online.
http://haproxy.1wt.eu/download/1.4/doc/configuration.txt
Global settings
# need to:
# /etc/sysconfig/syslog
log 127.0.0.1 local2
chroot      /var/lib/haproxy
maxconn     4000
user        haproxy
group       haproxy
# turn on stats unix socket
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
frontend main
bind 192.168.5.42:80
default_backend app
static backend for serving up images, stylesheets and such
backend static
server static 127.0.0.1:4331 check
round robin balancing between the various backends
backend app
server app1 192.168.5.50
server app2 192.168.5.51
RHEL-B Keepalived setup
global_defs {
router_id LVS_DEVEL
vrrp_strict
vrrp_gna_interval 0
state BACKUP
interface ens33
priority 100
advert_int 1
authentication {
auth_type PASS
auth_pass 1111
virtual_ipaddress {
delay_loop 10
protocol TCP
lb_algo rr
Use direct routing
lb_kind DR
    weight 1
    TCP_CHECK {
      connect_timeout 5
      connect_port 80
    weight 1
    TCP_CHECK {
      connect_timeout 5
      connect_port 80
RHEL-B HAProxy Setup
Global settings
# need to:
maxconn     4000
user        haproxy
group       haproxy
timeout queue 1m
timeout client 1m
timeout server 1m
timeout check 10s
maxconn 3000
frontend main
default_backend app
backend static
backend app
