Hope somebody can help I have run out of idea’s
Is it possible to run mysql cluster load balancing and https load load balancing on the same instance of haproxy ?
I have the following setup but I receive 10 minutes delay on the application when one of the mysql servers is shutdown I receive 503 error . If I manually restart the haproxy service the application comes back online
Cluster Application ( 2 Nodes )
MYSQL Cluster (2 Nodes )
Keepalive Virtual IP
The application connects to the virtual IP for the database cluster and application
I think I have configured the haproxy frontend or backend incorrectly
Any help would be much appreciated
Config
frontend http_front
bind *:443 ssl crt /etc/ssl/certs/mycert.pem
stats uri /haproxy?stats
default_backend http_back
backend http_back
option httpchk HEAD / HTTP/1.1\r\nHost:localhost
server FQDN 10.40.3.170:8080 cookie App1 check
server FQDN10.40.3.171:8080 cookie App2 check
