Layer4 health check failures while using option http-check
HI There,
I have 3 backend galera servers configured.
  user root
  group root
  ssl-default-server-ciphers kEECDH+aRSA+AES:kRSA+AES:+AES256:RC4-SHA:!kEDH:!LOW:!EXP:!MD5:!aNULL:!eNULL
  ssl-default-server-options no-sslv3
  stats socket /run/haproxy.sock mode 660 level admin
  option                  tcp-smart-accept
  option                  tcp-smart-connect
  timeout client 480m
  timeout server 480m
  timeout http-keep-alive 1s
  timeout http-request 15s
  timeout queue 30s
  timeout tarpit 1m
frontend mysql
  bind <IP>:3306
  default_backend mysql_nodes
backend mysql_nodes
  option tcp-check
  option httpchk
  server mysql-1 <IP1>:3306 backup check port 9200  maxconn 1500 inter 1s fall 5 rise 2
  server mysql-2 <IP2>:3306 check port 9200  maxconn 1500 inter 1s fall 5 rise 2
  server mysql-3 <IP3>:3306 check port 9200  maxconn 1500 inter 1s fall 5 rise 2
I have set up health check on port 9200 with Xinetd and scripts.
I could see in the log that the layer4 checks are failing and layer7 checks passing fine.
Server mysql_nodes/mysql-2 is DOWN, reason: Layer4 connection problem, info: "Connection refused", check duration: 133ms. 1 active and 1 backup servers left. 2 sessions active, 0 requeued, 0 remaining in queue.
Server mysql_nodes/mysql-2 is UP, reason: Layer7 check passed, code: 200, check duration: 457ms. 2 active and 1 backup servers online. 0 sessions requeued, 0 total in queue.
This configures only layer7 checks right? Is there a way in the configuration file to disable the layer4 checks?
I tried with tcp-check and mysql-check options but i am getting the same results.
Thanks for any help!!
Sounds like you may have another haproxy running in the background with an old configuration.
Can you check and kill old processes if any? Can you check haproxy PIDs in the log?
option tcp-check enables layer4 checks, this needs to be removed.
Thanks for the reply!!
There is no old haproxy process running in the background. There are 2 PIDs created by the haproxy service.
I am not using option tcp-check in the configuration.
Ok, can you provide a tcpdump ( tcpdump -i ethX -pns0 -w health-check-traffic.cap host <IP1> and port 9200 ) of the entire health check traffic as well as the output of haproxy -vv.
I am out for this week, i will provide it first thing on Monday.
Thanks for the help!!
I checked the tcpdump, although the script is sending “200 ok” there was lot of tcp retransmission and reset in the communication. I am trying to replace the bash script with a python script. I will update after making the changes.
Hi @lukastribus ,
Sorry for the late reply. I tried different healthcheck scripts, still getting the healthcheck failures.
please find the capture.
The HTTP traffic looks fine but there is a lot of TCP RST.
The response is 30 bytes long, but the Content-Length specifies 40 bytes. That is therefore certainly an invalid response.
Thank you for the response. I don’t know what is causing this. Let me check and get back.
Hi @lukastribus ,
Content length is set to 30 now. Still there are layer4 failures and TCP RST packets. Could you please take a look?
Right, the content length is actually 32 bytes, because after the trailing \r\n.
Hi @lukastribus ,
It’s the same with content length 32 bytes as well.
Not sure what happens here. Can you provide the output of haproxy -vv as well as run haproxy in debug mode manually (haproxy -f /path/to/config -d).
Also can you confirm the configuration in the first post is still what you are running?
Here are the details
$ haproxy -vv
HAProxy version 2.8.0-fdd8154 2023/05/31 - https://haproxy.org/
Status: long-term supported branch - will stop receiving fixes around Q2 2028.
Known bugs: http://www.haproxy.org/bugs/bugs-2.8.0.html
Running on: Linux 4.18.0-240.el8.x86_64 #1 SMP Fri Sep 25 19:48:47 UTC 2020 x86_64
  TARGET  = linux-glibc
  CPU     = generic
  CC      = cc
  CFLAGS  = -O2 -g -Wall -Wextra -Wundef -Wdeclaration-after-statement -Wfatal-errors -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wno-string-plus-int -Wno-atomic-alignment
  OPTIONS = USE_GETADDRINFO=1 USE_OPENSSL=yes USE_LUA=yes USE_ZLIB=yes USE_SYSTEMD=yes USE_PROMEX=yes USE_PCRE=yes USE_PCRE_JIT=yes
  DEBUG   = -DDEBUG_STRICT -DDEBUG_MEMORY_POOLS
Feature list : -51DEGREES +ACCEPT4 +BACKTRACE -CLOSEFROM +CPU_AFFINITY +CRYPT_H -DEVICEATLAS +DL -ENGINE +EPOLL -EVPORTS +GETADDRINFO -KQUEUE -LIBATOMIC +LIBCRYPT +LINUX_SPLICE +LINUX_TPROXY +LUA +MATH -MEMORY_PROFILING +NETFILTER +NS -OBSOLETE_LINKER +OPENSSL -OPENSSL_WOLFSSL -OT +PCRE -PCRE2 -PCRE2_JIT +PCRE_JIT +POLL +PRCTL -PROCCTL +PROMEX -PTHREAD_EMULATION -QUIC +RT +SHM_OPEN -SLZ +SSL -STATIC_PCRE -STATIC_PCRE2 +SYSTEMD +TFO +THREAD +THREAD_DUMP +TPROXY -WURFL +ZLIB
Built with multi-threading support (MAX_TGROUPS=16, MAX_THREADS=256, default=8).
Built with OpenSSL version : OpenSSL 3.0.9 30 May 2023
Running on OpenSSL version : OpenSSL 3.0.9 30 May 2023
Built with Lua version : Lua 5.3.6
Built with zlib version : 1.2.13
Running on zlib version : 1.2.13
Built with PCRE version : 8.45 2021-06-15
Running on PCRE version : 8.45 2021-06-15
Built with gcc compiler version 12.3.0
	[BWLIM] bwlim-in
	[BWLIM] bwlim-out
	[FCGI] fcgi-app
$ sudo haproxy -f /etc/haproxy/haproxy.conf -d
Note: setting global.maxconn to 131046.
     select : pref=150,  test result FAILED
Total: 3 (2 usable), will use epoll.
	[BWLIM] bwlim-in
	[BWLIM] bwlim-out
	[FCGI] fcgi-app
Using epoll() as the polling mechanism.
[WARNING]  (12136) : Server mysql_nodes/mysql-2 is DOWN, reason: Layer4 connection problem, info: "Connection refused", check duration: 183ms. 2 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
[WARNING]  (12136) : Server mysql_nodes/mysql-3 is DOWN, reason: Layer4 connection problem, info: "Connection refused", check duration: 183ms. 1 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
[WARNING]  (12136) : Server mysql_nodes/mysql-2 is UP, reason: Layer7 check passed, code: 200, check duration: 610ms. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
[WARNING]  (12136) : Server mysql_nodes/mysql-1 is DOWN, reason: Layer4 connection problem, info: "Connection refused", check duration: 159ms. 1 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
[WARNING]  (12136) : Server mysql_nodes/mysql-3 is UP, reason: Layer7 check passed, code: 200, check duration: 610ms. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Yes , I am running the same configuration
I have recreated the situation with your exact release and configuration and I don’t see any issues.
However looking at your traces again it becomes clear that I was too focused on the HTTP transaction. The haproxy log was correct all along and the traces confirm it:
Sometimes the Port 9200 responds (and then the health check succeeds), and sometimes the TCP handshake to port 9200 is just flat out rejected (SYN → RST, ACK).
It looks like your health check script is unable to continuously respond.
Thanks for the reply. I will replace the script and check.
Hi ,
The issue is fixed with the new python script. Thanks for the help !!
Hi Katz,
We have the same issue. Would you mind to share your python script here…? Or can we find it on github, or such…?
For reference, we came up with this:
#!/usr/bin/env python3
import subprocess
import sys
import os
import time
# Function to load the config file and remove quotes around values
def load_config(config_file):
    config = {}
    with open(config_file, 'r') as f:
        for line in f:
            # Ignore comments and empty lines
            line = line.strip()
            if not line or line.startswith('#'):
                continue
            key, value = line.split('=', 1)
            # Strip surrounding quotes from value
            config[key.strip()] = value.strip('"').strip("'")
    return config
# Function to send the HTTP reply (used for returning status codes)
def httpReply(HTTP_STATUS, RESPONSE_CONTENT):
    CONTENT_LENGTH = len(RESPONSE_CONTENT)
    if HTTP_STATUS == "503":
        print("HTTP/1.1 503 Service Unavailable")
    elif HTTP_STATUS == "200":
        print("HTTP/1.1 200 OK")
    else:
        print(f"HTTP/1.1 {HTTP_STATUS}")
    print("Content-Type: text/plain")
    print("Connection: close")
    print(f"Content-Length: {CONTENT_LENGTH}")
    print()  # Blank line after headers
    print(RESPONSE_CONTENT)
    time.sleep(0.1)
# Function to execute the MySQL command and fetch status
def get_mysql_status(command):
    try:
        result = subprocess.run(command, stdout=subprocess.PIPE, stderr=subprocess.PIPE, check=True, text=True)
        # Return the output as a list of lines, stripping unnecessary spaces
        return result.stdout.strip().splitlines()
    except subprocess.CalledProcessError as e:
        return None
# Main function
def main():
    # Load configuration
    config_file = '/etc/sysconfig/clustercheck'
    if not os.path.exists(config_file):
        print(f"Config file {config_file} does not exist.")
        sys.exit(1)
    config = load_config(config_file)
    # Get configuration values, using defaults if necessary
    MYSQL_USERNAME = config.get('MYSQL_USERNAME', 'clustercheckuser')
    MYSQL_PASSWORD = config.get('MYSQL_PASSWORD', 'clustercheckpassword!')
    AVAILABLE_WHEN_DONOR = int(config.get('AVAILABLE_WHEN_DONOR', 0))
    ERR_FILE = config.get('ERR_FILE', '/dev/null')
    AVAILABLE_WHEN_READONLY = int(config.get('AVAILABLE_WHEN_READONLY', 1))
    DEFAULTS_EXTRA_FILE = config.get('DEFAULTS_EXTRA_FILE', '/etc/my.cnf')
    TIMEOUT = int(config.get('TIMEOUT', 10))
    # Timeout exists for instances where mysqld may be hung
    EXTRA_ARGS = []
    if MYSQL_USERNAME:
        EXTRA_ARGS.append(f"--user={MYSQL_USERNAME}")
    if MYSQL_PASSWORD:
        EXTRA_ARGS.append(f"--password={MYSQL_PASSWORD}")
    if os.path.isfile(DEFAULTS_EXTRA_FILE):
        MYSQL_CMDLINE = [
            'mysql', '--defaults-extra-file=' + DEFAULTS_EXTRA_FILE, '-nNE',
            '--connect-timeout=' + str(TIMEOUT)
        ] + EXTRA_ARGS
    else:
        MYSQL_CMDLINE = [
            'mysql', '-nNE', '--connect-timeout=' + str(TIMEOUT)
        ] + EXTRA_ARGS
    # Check the wsrep_local_state
    WSREP_STATUS = get_mysql_status(MYSQL_CMDLINE + ["-e", "SHOW STATUS LIKE 'wsrep_local_state';"])
    if not WSREP_STATUS:
        httpReply("503", "Received empty reply from Percona XtraDB Cluster Node.\r\nMight be a permission issue, check the credentials used by the script.")
        sys.exit(1)
    # Now, we handle the state based on the fetched status
    wsrep_state = WSREP_STATUS[-1].split()[-1]
    if wsrep_state == "4" or (wsrep_state == "2" and AVAILABLE_WHEN_DONOR == 1):
        if AVAILABLE_WHEN_READONLY == 0:
            # Check if the node is in read-only mode
            READ_ONLY = get_mysql_status(MYSQL_CMDLINE + ["-e", "SHOW GLOBAL VARIABLES LIKE 'read_only';"])
            if READ_ONLY and 'ON' in READ_ONLY[-1]:
                httpReply("503", "Percona XtraDB Cluster Node is read-only.\r\n")
                sys.exit(1)
        httpReply("200", "Percona XtraDB Cluster Node is synced.\r\n")
        sys.exit(0)
    else:
        else:
            httpReply("503", "Percona XtraDB Cluster Node is not synced.\r\n")
        sys.exit(1)
if __name__ == "__main__":
    main()
For the record: I am now testing the python version above, to see if this works better than the original bash clustercheck script. Most of the python code was generated through chatgpt, by the way. But it seems to work nicely, so far.
Just updating here. We see less of them, but still get an occasional “socket error”, and the haproxy status changes to purple for the affected backend server. After a few seconds, it changes back to green and “succeeded” in haproxy.log
If anyone has insights to share, we would appreciate feedback.
