Thanks Lukastribus for your answer
I don’t get how the fact that my redis backend have a redis master or not influence how “tcp-check connect” failed, there is no relationship with the error returned by “tcp-check connect” and the fact i have a master or not, if it was the case the error will be not :
Layer4 connection problem, info: “Connection refused at step 1 of tcp-check (connect)”
but something like:
at step 5 of tcp-check (expect string 'role:master')
Here a concrete example with 2 proxies targeting the same hosts with the same config.
1 host under centos and another one on debian 9 (haproxy from package distrib)
$ docker exec -ti proxy-1-centos-7 haproxy -v
Copyright 2000-2016 Willy Tarreau <willy@haproxy.org>
$ docker exec -ti proxy-2-debian-9 haproxy -v
HA-Proxy version 1.7.5-2 2017/05/17
Copyright 2000-2017 Willy Tarreau <willy@haproxy.org>
same config on both:
$ docker exec -ti proxy-1-centos-7 cat /etc/haproxy/haproxy.cfg
log /dev/log local2
stats socket /var/lib/haproxy/stats.sock mode 660 level admin process 1
stats bind-process 1
chroot /var/lib/haproxy/
maxconn 200000
nbproc 4
frontend ft_redis
bind 172.28.5.253:6379 name redis
default_backend bk_redis
backend bk_redis
option tcp-check
tcp-check connect
tcp-check send PING\r\n
tcp-check expect string +PONG
tcp-check send info\ replication\r\n
tcp-check expect string role:master
tcp-check send QUIT\r\n
tcp-check expect string +OK
server redis-1-centos-7 redis-1-centos-7:6379 check inter 1s
server redis-2-centos-7 redis-2-centos-7:6379 check inter 1s
server redis-3-centos-7 redis-3-centos-7:6379 check inter 1s
$ diff <(docker exec proxy-1-centos-7 cat /etc/haproxy/haproxy.cfg) <(docker exec proxy-2-debian-9 cat /etc/haproxy/haproxy.cfg)
But haproxy failed on the debian version and not on centos
Centos:
$ docker exec -ti proxy-1-centos-7 bash -c 'echo "show stat" | socat /var/lib/haproxy/stats.sock stdio'
# pxname,svname,qcur,qmax,scur,smax,slim,stot,bin,bout,dreq,dresp,ereq,econ,eresp,wretr,wredis,status,weight,act,bck,chkfail,chkdown,lastchg,downtime,qlimit,pid,iid,sid,throttle,lbtot,tracked,type,rate,rate_lim,rate_max,check_status,check_code,check_duration,hrsp_1xx,hrsp_2xx,hrsp_3xx,hrsp_4xx,hrsp_5xx,hrsp_other,hanafail,req_rate,req_rate_max,req_tot,cli_abrt,srv_abrt,comp_in,comp_out,comp_byp,comp_rsp,lastsess,last_chk,last_agt,qtime,ctime,rtime,ttime,
ft_redis,FRONTEND,,,0,0,2000,0,0,0,0,0,0,,,,,OPEN,,,,,,,,,1,2,0,,,,0,0,0,0,,,,,,,,,,,0,0,0,,,0,0,0,0,,,,,,,,
bk_redis,redis-1-centos-7,0,0,0,0,,0,0,0,,0,,0,0,0,0,UP,1,1,0,0,0,128,0,,1,3,1,,0,,2,0,,0,L7OK,0,1,,,,,,,0,,,,0,0,,,,,-1,(tcp-check),,0,0,0,0,
bk_redis,redis-2-centos-7,0,0,0,0,,0,0,0,,0,,0,0,0,0,DOWN,1,1,0,1,1,126,126,,1,3,2,,0,,2,0,,0,L7TOUT,,1001,,,,,,,0,,,,0,0,,,,,-1, at step 5 of tcp-check (expect string 'role:master'),,0,0,0,0,
bk_redis,redis-3-centos-7,0,0,0,0,,0,0,0,,0,,0,0,0,0,DOWN,1,1,0,1,1,126,126,,1,3,3,,0,,2,0,,0,L7TOUT,,1001,,,,,,,0,,,,0,0,,,,,-1, at step 5 of tcp-check (expect string 'role:master'),,0,0,0,0,
bk_redis,BACKEND,0,0,0,0,200,0,0,0,0,0,,0,0,0,0,UP,1,1,0,,0,128,0,,1,3,0,,0,,1,0,,0,,,,,,,,,,,,,,0,0,0,0,0,0,-1,,,0,0,0,0,
Debian:
$ docker exec -ti proxy-2-debian-9 bash -c 'echo "show stat" | socat /var/lib/haproxy/stats.sock stdio'
# pxname,svname,qcur,qmax,scur,smax,slim,stot,bin,bout,dreq,dresp,ereq,econ,eresp,wretr,wredis,status,weight,act,bck,chkfail,chkdown,lastchg,downtime,qlimit,pid,iid,sid,throttle,lbtot,tracked,type,rate,rate_lim,rate_max,check_status,check_code,check_duration,hrsp_1xx,hrsp_2xx,hrsp_3xx,hrsp_4xx,hrsp_5xx,hrsp_other,hanafail,req_rate,req_rate_max,req_tot,cli_abrt,srv_abrt,comp_in,comp_out,comp_byp,comp_rsp,lastsess,last_chk,last_agt,qtime,ctime,rtime,ttime,agent_status,agent_code,agent_duration,check_desc,agent_desc,check_rise,check_fall,check_health,agent_rise,agent_fall,agent_health,addr,cookie,mode,algo,conn_rate,conn_rate_max,conn_tot,intercepted,dcon,dses,
ft_redis,FRONTEND,,,0,0,2000,0,0,0,0,0,0,,,,,OPEN,,,,,,,,,1,2,0,,,,0,0,0,0,,,,,,,,,,,0,0,0,,,0,0,0,0,,,,,,,,,,,,,,,,,,,,,tcp,,0,0,0,,0,0,
bk_redis,redis-1-centos-7,0,0,0,0,,0,0,0,,0,,0,0,0,0,DOWN,1,1,0,1,1,110,110,,1,3,1,,0,,2,0,,0,L4CON,,0,,,,,,,,,,,0,0,,,,,-1,Connection refused at step 1 of tcp-check (connect),,0,0,0,0,,,,Layer4 connection problem,,2,3,0,,,,172.28.5.0:6379,,tcp,,,,,,,,
bk_redis,redis-2-centos-7,0,0,0,0,,0,0,0,,0,,0,0,0,0,DOWN,1,1,0,1,1,109,109,,1,3,2,,0,,2,0,,0,L4CON,,0,,,,,,,,,,,0,0,,,,,-1,Connection refused at step 1 of tcp-check (connect),,0,0,0,0,,,,Layer4 connection problem,,2,3,0,,,,172.28.5.1:6379,,tcp,,,,,,,,
bk_redis,redis-3-centos-7,0,0,0,0,,0,0,0,,0,,0,0,0,0,DOWN,1,1,0,1,1,109,109,,1,3,3,,0,,2,0,,0,L4CON,,0,,,,,,,,,,,0,0,,,,,-1,Connection refused at step 1 of tcp-check (connect),,0,0,0,0,,,,Layer4 connection problem,,2,3,0,,,,172.28.5.2:6379,,tcp,,,,,,,,
bk_redis,BACKEND,0,0,0,0,200,0,0,0,0,0,,0,0,0,0,DOWN,0,0,0,,1,109,109,,1,3,0,,0,,1,0,,0,,,,,,,,,,,,,,0,0,0,0,0,0,-1,,,0,0,0,0,,,,,,,,,,,,,,tcp,roundrobin,,,,,,,
In theory, because if I remove tcp-check connect, the check seems to behave as it needs to
$ docker exec -ti proxy-2-debian-9 cat /etc/haproxy/haproxy.cfg
log /dev/log local2
maxconn 200000
nbproc 4
frontend ft_redis
backend bk_redis
option tcp-check
bk_redis,redis-1-centos-7,0,0,0,0,,0,0,0,,0,,0,0,0,0,UP,1,1,0,0,0,18,0,,1,3,1,,0,,2,0,,0,L7OK,0,2,,,,,,,,,,,0,0,,,,,-1,(tcp-check),,0,0,0,0,,,,Layer7 check passed,,2,3,4,,,,172.28.5.0:6379,,tcp,,,,,,,,
bk_redis,redis-2-centos-7,0,0,0,0,,0,0,0,,0,,0,0,0,0,DOWN,1,1,0,1,1,17,17,,1,3,2,,0,,2,0,,0,L7TOUT,,1002,,,,,,,,,,,0,0,,,,,-1, at step 4 of tcp-check (expect string 'role:master'),,0,0,0,0,,,,Layer7 timeout,,2,3,0,,,,172.28.5.1:6379,,tcp,,,,,,,,
bk_redis,redis-3-centos-7,0,0,0,0,,0,0,0,,0,,0,0,0,0,DOWN,1,1,0,1,1,17,17,,1,3,3,,0,,2,0,,0,L7TOUT,,1001,,,,,,,,,,,0,0,,,,,-1, at step 4 of tcp-check (expect string 'role:master'),,0,0,0,0,,,,Layer7 timeout,,2,3,0,,,,172.28.5.2:6379,,tcp,,,,,,,,
bk_redis,BACKEND,0,0,0,0,200,0,0,0,0,0,,0,0,0,0,UP,1,1,0,,0,18,0,,1,3,0,,0,,1,0,,0,,,,,,,,,,,,,,0,0,0,0,0,0,-1,,,0,0,0,0,,,,,,,,,,,,,,tcp,roundrobin,,,,,,,
