I am replacing httpd by Nginx on my platform (httpd, Nginx and wordpress), but I have a problem blocking.
My architecture is as follows:
INTERNET --------https------> HAPROXY (SSL) -------> http ------> NGinx -------> Wordpress.
I have installed / configured haproxy and nginx. Both work and my site is in HTTPS. SSL is managed by HAProxy and Nginx does not do SSL.
Now I downloaded and unzipped wordpress. To follow the installation, I went to the homepage from an internet browser and problems begin.
On the homepage for installing wordpress, CSS and java scripts are not loaded whereas the same architecture works with httpd instead of NGinx.
any idea?
My configurations:
#####HAProxy
frontend https-in
bind X.X.X.X:443 ssl crt /etc/pki/certs
option httplogacl my_site hdr(host) -i mon.site.fr use_backend wp if my_site rspadd Strict-Transport-Security:\ max-age=15768000backend wp
server wp_1 X.X.X.X:8080
#####NGinx
server {
listen *:8080;
server_name mon.site.fr;root /var/www/html/site1; access_log /var/log/nginx/site1.access.log; error_log /var/log/nginx/site1.error.log; location / { index index.php index.html; try_files $uri $uri/ /index.php?$args; } if (!-e $request_filename) { rewrite ^.*$ /index.php last; } location = /favicon.ico { log_not_found off; access_log off; } location = /robots.txt { log_not_found off; access_log off; allow all; } location ~ /\. { deny all; } location ~* /(?:uploads|files)/.*\.php$ { deny all; } location ~* \.(html|css|js|png|jpg|jpeg|gif|ico|svg|eot|woff|ttf)$ { expires max; log_not_found off; } location ~ \.php$ { try_files $uri =404; fastcgi_pass unix:/var/run/php70-fpm.mon.site.fr.sock; fastcgi_index index.php; fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name; fastcgi_param SCRIPT_NAME $fastcgi_script_name; fastcgi_buffer_size 128k; fastcgi_buffers 256 16k; fastcgi_busy_buffers_size 256k; fastcgi_temp_file_write_size 256k; include fastcgi_params; }}
http {
log_format main '$remote_addr - $remote_user [$time_local] “$request” ’
'$status $body_bytes_sent “$http_referer” ’
‘“$http_user_agent” “$http_x_forwarded_for”’;access_log /var/log/nginx/access.log main; sendfile on; tcp_nopush on; tcp_nodelay on; keepalive_timeout 65; types_hash_max_size 2048; include /etc/nginx/mime.types; default_type application/octet-stream; include /etc/nginx/sites-enabled/*.conf; # Real IP set_real_ip_from X.X.X.X; real_ip_header X-Forwarded-For; gzip on; gzip_disable "msie6"; gzip_vary on; gzip_proxied any; gzip_comp_level 6; gzip_buffers 16 8k; gzip_http_version 1.1; gzip_types text/plain text/css application/json application/javascript application/x-javascript text/xml application/xml application/xml+rss text/javascript;}
Thanx
