I’m new here, and I need help with my conf.
I have several server behind my Haproxy, everything works well but my wordpress is not working on mobile device. Works with all nav on desktop, but on mobile works only with safari.
Here’s my conf, problem is with dom7
ssl-default-bind-ciphers xxxx
frontend http-in
acl http ssl_fc,not
frontend ft_https
bind *:443 ssl crt-list /etc/haproxy/certs/domains_list.txt
default_backend bk_exchange
acl ft_owa hdr(host) -i ex1.xxxx
use_backend bk_exchange if ft_owa
use_backend letsencrypt-back if letsencrypt-acl
acl host_dom1 hdr_end(host) -i autodiscover.xxxx
acl host_dom2 hdr_end(host) -i nextcloud.xxxx
use_backend bk_exchange if host_dom1
use_backend dom2-back if host_dom2
acl host_dom3 hdr_end(host) -i www.xxxxxx
use_backend dom5-back if host_dom3
acl host_dom6 hdr_end(host) -i xxxx
use_backend dom5-back if host_dom6
acl host_dom7 hdr_end(host) -i www.xxxx
use_backend dom7-back if host_dom7
backend bk_exchange
acl path_root url_len 1
acl path_exchange path_beg -i /autodiscover /owa /oab /ews /public /microsoft-server-activesync /rpc /mapi /favicon.ico
http-request deny unless path_exchange OR path_root
server exchange xxx.xxx.xxx.xxx:443 check ssl verify none
backend dom1-back
server dom1 xxx.xxx.xxx.xxx:443
backend dom2-back
redirect scheme https if ! { ssl_fc }
server dom2 xxx.xxx.xxx.xxx:443 check ssl verify none
backend dom3-back
server dom3 xxx.xxx.xxx.xxx:443 check ssl verify none
backend dom5-back
server dom5 xxx.xxx.xxx.xxx:443 check ssl verify none
backend dom7-back
server dom7 xxx.xxx.xxx.xxx:443 check ssl verify none
