Hi!
My config looks like this
uid 80
gid 80
chroot /var/haproxy
stats socket /var/run/haproxy.socket group proxy mode 775 level admin
nbproc 1
nbthread 4
hard-stop-after 60s
no strict-limits
maxconn 10000
spread-checks 2
tune.bufsize 16384
tune.lua.maxmem 0
log /var/run/log local0 info
lua-prepend-path /tmp/haproxy/lua/?.lua
option redispatch -1
maxconn 5000
timeout client 30s
timeout connect 30s
timeout server 30s
default-server init-addr last,libc
default-server maxconn 5000
# Frontend: SNI_frontend (Listening o)
frontend SNI_frontend
bind 0.0.0.0:443 name 0.0.0.0:443
bind 0.0.0.0:80 name 0.0.0.0:80
default_backend SSL_backend
# tuning options
timeout client 30s
# logging options
# Frontend: HTTP_frontend (Listening 127.0.0.1:80)
frontend HTTP_frontend
bind 127.0.0.1:80 name 127.0.0.1:80 accept-proxy
# tuning options
timeout client 30s
# logging options
# ACL: NoSSL_condition
acl acl_621d0b77c74989.24704837 req.ssl_ver gt 0
# ACTION: HTTPtoHTTPS_rule
http-request redirect scheme https code 301 if !acl_621d0b77c74989.24704837
# Frontend: HTTPS_frontend (Listinging on 127.0.0.1:443)
frontend HTTPS_frontend
http-response set-header Strict-Transport-Security "max-age=63072000; includeSubDomains; preload"
bind 127.0.0.1:443 name 127.0.0.1:443 accept-proxy ssl curves secp384r1 no-sslv3 no-tlsv10 no-tlsv11 no-tls-tickets ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES256-GCM-SHA384 ciphersuites TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256 alpn h2,http/1.1 crt-list /tmp/haproxy/ssl/621d11c7cad951.61400293.certlist
default_backend WEBSERVER_backend
# tuning options
timeout client 15m
# logging options
# ACTION: PUBLIC_SUBDOMAINS_map-rule
# NOTE: actions with no ACLs/conditions will always match
use_backend %[req.hdr(host),lower,map_dom(/tmp/haproxy/mapfiles/621d0c7054ddb7.46420139.txt)]
# Backend: SSL_backend ()
backend SSL_backend
# health checking is DISABLED
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
server SSL_server 127.0.0.1 send-proxy-v2 check-send-proxy
# Backend: WEBSERVER_backend ()
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server WEBSERVER_server 192.168.1.100:80 send-proxy-v2 check-send-proxy
# Backend: NAS_backend ()
backend NAS_backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server NAS_server 192.168.1.118:81 send-proxy-v2 check-send-proxy
but my site looks very bad
How I can change this?
Other subdomains are working. Like https://nas.joelmueller.ch
