Haproxy error 301 with apache2 rewrite rules
Hi everybody,
I try to setup haproxy as a reverse proxy to redirect web queries to different servers.
But I have a problem with wordpress servers under apache2 using rewrite rules to redirect hhtp queries to https.
On the client side I got a “The page isn’t redirecting properly” message
On the haproxy server I got this in the haproxy.log :
Nov  8 14:12:48 rproxy haproxy[1087]: 10.5.0.176:59316 [08/Nov/2018:14:12:48.122] https-in~ bk_webtest2/webtest2 0/0/0/1/1 301 548 - - ---- 1/1/0/1/0 0/0 "GET / HTTP/1.1"
Nov  8 14:12:48 rproxy haproxy[1087]: 10.5.0.176:59316 [08/Nov/2018:14:12:48.127] https-in~ bk_webtest2/webtest2 0/0/0/2/2 301 548 - - ---- 1/1/0/1/0 0/0 "GET / HTTP/1.1"
Nov  8 14:12:48 rproxy haproxy[1087]: 10.5.0.176:59316 [08/Nov/2018:14:12:48.165] https-in~ bk_webtest2/webtest2 0/0/0/1/1 301 548 - - ---- 1/1/0/1/0 0/0 "GET / HTTP/1.1"
Nov  8 14:12:48 rproxy haproxy[1087]: 10.5.0.176:59316 [08/Nov/2018:14:12:48.185] https-in~ bk_webtest2/webtest2 0/0/0/2/2 301 548 - - ---- 1/1/0/1/0 0/0 "GET / HTTP/1.1"
Nov  8 14:12:48 rproxy haproxy[1087]: 10.5.0.176:59316 [08/Nov/2018:14:12:48.198] https-in~ bk_webtest2/webtest2 0/0/0/1/1 301 548 - - ---- 1/1/0/1/0 0/0 "GET / HTTP/1.1"
Nov  8 14:12:48 rproxy haproxy[1087]: 10.5.0.176:59316 [08/Nov/2018:14:12:48.219] https-in~ bk_webtest2/webtest2 0/0/0/2/2 301 548 - - ---- 1/1/0/1/0 0/0 "GET / HTTP/1.1"
On the apache web server, I got this :
10.5.0.43 - - [08/Nov/2018:12:56:01 +0000] "GET / HTTP/1.1" 301 548 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:62.0) Gecko/20100101 Firefox/62.0"
Here is (part of) my haproxy.cfg :
frontend https-in
	bind *:443 ssl crt-list /etc/haproxy/crt-list.txt
	acl acl_webtest2 hdr(host) webtest2.pierrefitte93.fr
	use_backend bk_webtest2 if acl_webtest2
backend bk_webtest2
	option httpchk
#	option forwardfor except 127.0.0.1
#	http-request redirect scheme https if ! { ssl_fc }
	server webtest2 10.5.0.87:80
And, finally, the apache2 rewrite rule :
#Redirect to SSL version
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule .* https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
Can anybody help me about this problem ?
Regards,
JPW
Don’t redirect in Apache, wordpress will already do that, just make sure you communicate the fact that haproxy is terminating HTTPS properly from Haproxy to Apache and from Apache to wordpress:
In haproxy set the X-Forwarded-Proto header, based on whether the request comes in as HTTP or HTTPS:
http-request set-header X-Forwarded-Proto http if ! { ssl_fc }
In Apache, configure something like this:
<IfModule mod_setenvif.c>
  SetEnvIf X-Forwarded-Proto "^https$" HTTPS
</IfModule>
Stolen from:
You can decide whether or not you want to redirect to https on haproxy; it’s probably not necessary because wordpress will do that.
Many thanks, it works perfectly !
