Not sure if this is a bug or some misconfiguration
System:
HAProxy lrunnign as a K8s container pod and load balancing services in a k8s cluster with HAProxy backends pointing at k8s services
Desired behavior :
- Some services might not exist when HAProxy is started .
- HAProxy should start without erroring out because some services/backends do not exist
- When the services are created, HAProxy should serve traffic to them
Actual Behavior:
HAProxy disables the services at startup
- When the services are created, HAProxy does not recognize that they are up and errors out (503) when web requests are issued (503) unless HAProxy container is restarted or configuration reloaded
- I tried this with a variety of HAPRoxy 2.x versions and 3.1
- I tried using the no-check option to prevent disabling servers but it didn’t seem to work - HAProxy version 3.1.1 - Configuration Manual
Log
[NOTICE] (1) : [/etc/haproxy/haproxy.cfg:285] : 'server mysvc/mysvc' : could not resolve address 'mysvc-abc123.mynamespace.svc', disabling server.
Config
# Add X-Forwarded-For headers to each request
# so backend sees request as coming from the client's IP address, not LB's.
option forwardfor except 127.0.0.1/8
option abortonclose
retries 1
timeout client 10m
timeout server 10m
timeout connect 4s
timeout http-keep-alive 20s
default-server inter 30s slowstart 10s rise 1 fall 60 maxconn 500 weight 100 init-addr libc,none
relevant config
backend mysvc ======> LINE 285
server mysvc mysvc-abc123.mynamespace.svc:8081 no-check
