I am doing measurement of grpc by sending around 640MB data from grpc server. when my grpc client directly querying for data to grpc i am getting these 640MB within 700 ms. But when I am passing the request over HAProxy its turning out to be 1400 ms
From the haproxy logs it seems that Haproxy is getting request with grpc encoding as grpc . But in my code i have not set any encoding.
If I directly send request from grpc client to grpc server I can see this encoding is not present in http header.
HAProxy logs ->>>>>>>>>>
00000005:f_h2c.clireq[001e:ffffffff]: POST http://com.mycompany/com.mycompany.myproto.EchoService/echo HTTP/2.000000005:f_h2c.clihdr[001e:ffffffff]: content-type: application/grpc
00000005:f_h2c.clihdr[001e:ffffffff]: te: trailers
00000005:f_h2c.clihdr[001e:ffffffff]: user-agent: grpc-java-netty/1.19.0
00000005:f_h2c.clihdr[001e:ffffffff]: grpc-accept-encoding: gzip
00000005:f_h2c.clihdr[001e:ffffffff]: grpc-timeout: 4706532u
00000005:f_h2c.clihdr[001e:ffffffff]: host: com.mycompany
00000005:local_node.srvrep[001e:001f]: HTTP/2.0 200
00000005:local_node.srvhdr[001e:001f]: content-type: application/grpc
00000005:local_node.srvhdr[001e:001f]: grpc-encoding: identity
00000005:local_node.srvhdr[001e:001f]: grpc-accept-encoding: gzip
00000005:local_node.srvcls[001e:001f]
Is there any way to disable this gzip for Grpc in HaProxy side.
here is the config I am using
timeout client 30s
timeout server 30s
option logasap
option http-use-htx
frontend f_h2c
option http-use-htx
bind *:9211 proto h2
default_backend local_node
backend local_node
default-server inter 1s fall 1
server server1 10.204.11.33:8086 check proto h2
server server2 10.204.11.33:8085 check backup proto h2
