Hello everyone, I use nextcloud and in the summary information the following inscription appears:
The reverse proxy header configuration is incorrect
I think this is an error regarding HTTP “X-Forwarded-For” . I’ve tried different configurations by reading a little on the forums, but nothing to do.
Has anyone solved it?
Is your nextcloud web server is configure to understand X-Forwarded-For ?
Can real client user is readable in web server logs ?
Hi Deux, I forgot to write that I solved it after days. In the trusted proxies , I added the name fqdn of haproxy and from that moment on I have no more errors . Thank you anyway for your intervention.
'trusted_proxies' =>
array (
0 => '192.168.3.0/24',
1 => '192.168.1.2',
2 => '127.0.0.1',
3 => 'localhost',
4 => '::1',
5 => 'myhaproxy.fqdn',
'forwarded_for_headers' =>
array (
Remember to mark your solution as it.
