Hi all,
I am running haproxy inside pfsense.
I need to provide X-Forwarded headers for an application (kimai 2) I just installed inside a container in my proxmox server. The app is running behind haproxy, so this is necessary in order for it to work properly. The app’s documentation provides instructions and a configuration example using nginx; see here and the screenshot below for details:
Could you please help me understand how to do this in haproxy?
What I have tried so far is to check the box “Use “forwardfor” option” under “advanced settings” in my frontend but this did not fix the issues I am having with the https url redirecting to http and the browser timing out when I try to reach the app. I guess there is something I need to do inside the app’s backend, but where exactly?
Thanks a lot in advance for any tips.
