Having the weirdest issue with HAProxy… this is an example front/backend I have:
# telnet
frontend fe-telnet
bind :::23
bind :23
default_backend be-telnet
backend be-telnet
stick-table type ip size 20k expire 30m
stick on src
server sbbs 10.16.16.2:230 send-proxy-v2
Yet in the logs I can see:
haproxy | Connect from 77.90.185.18:41992 to 10.0.0.191:587 (fe-smtp-submit/TCP)
It should be forwarding to 10.16.16.2, but it forwards to 10.0.0.191. I am running haproxy in docker with host network mode. Can someone help me troubleshoot this? 10.16.16.2 is pingable from the host.
