I am running Raspbian on a Raspberry Pi at home, hosting my own Nextcloud instance using Apache2 as the webserver. In order to make it accessible from outside and look “professional” with my own URL without any port numbers attached, I am using the following setup:
- My domain (let’s call it iyassin.de) is attached to my CentOS-based managed webspace (Uberspace, if anyone knows them)
- Subdomain cloud.iyassin.de is created as a folder in the webroot, containing a .htaccess with the following code in order to direct all traffic to HAproxy:
RewriteEngine On
RewriteCond %{HTTP:X-Forwarded-Server} ^$
RewriteRule (.*) http://localhost:12345/$1 [P]
- Managed webspace is running an HAproxy instance listening on port 12345, pointing to nextcloud.mydyndnsservice.eu:443
- Apache2 on Raspberry Pi answers the request using a VirtualHost configuration matching cloud.iyassin.de and serving the correct Letsencrypt SSL certificate that I have copied to the Pi from the managed webspace. It also has its own certificate when accessed directly through nextcloud.mydyndnsservice.eu:443, so that the connection to HAproxy is also encryped.
This used to work perfectly for over a year, redirecting my browser to https://cloud.iyassin.de/index.php/login. A few days ago, it failed - when I access https://cloud.iyassin.de, it’ll redirect now my browser to https://localhost:12345/index.php/login which of course fails.
What could this be caused by? The Apache rewrite is still working, as I can change the port number. The HAproxy is working, as killing it will produce an 503 error instead of the wrong redirection. Also it establishes the connection to my Raspberry Pi as it gets the correct login path, but it just fails to correctly rewrite the URL.
Here’s my haproxy.cfg as well:
frontend HTTP
bind 127.0.0.1:63847
timeout client 5000
acl a_example hdr(X-Forwarded-Host) -i cloud.iyassin.de
use_backend b_example if a_example
default_backend uberspace_81
timeout connect 3000
timeout server 3000
server uberspace 123.456.789.123:81
backend b_example
timeout server 7200000
server server1-a nextcloud.mydyndnsservice.eu:443 ssl ca-file /etc/ssl/certs/ca-bundle.trust.crt
