I am using HAproxy with version 1.5.18.
There is a weird pattern for timeout client value which cause HAproxy works or return 408/504 error when added it to the fronted section.
For example:
Values equal or above 1us and below 25d are working (application behind the HAproxy can be accessed).
Values equal or above 25d and below 50d are NOT working (application behind the HAproxy can NOT be accessed).
Values equal or above 50d and below 75d are working
Values equal or above 75d and below 100d are NOT working
Values equal or above 100d and below 125d are working
Values equal or above 125d and below 150d are NOT working
and this pattern continues forever every 25 days.
When the application cannot be accessed, a 408 or 504 error is returned.
In the access log, the session is terminated with “cC” state as following:
“GET /index.html HTTP/1.1” 504 194 “” “” 58568 614 “http_vip” “http-pool” “m1” 0 0 0 -1 0 cC-- 0 0 0 0 0 0 0 “” “”
I have tried with tcp mode, still has the same result.
Built without zlib support (USE_ZLIB not set)
Compression algorithms supported : identity
Built with OpenSSL version : OpenSSL 1.0.2p-fips 14 Aug 2018
Running on OpenSSL version : OpenSSL 1.0.2p-fips 14 Aug 2018
Built with PCRE version : 8.42 2018-03-20
Hi Lukas!
Well I’m embarrassed, I was absolutely certain it was documented… and I was wrong! The only place where I find such a mention in the doc is on the stick-table expire keyword. Not only we need to add to add it in the configuration, but we also need to check it during parsing (and yes, I was pretty sure it was tested as well). Let’s fix this before 2.0. Ideally we need to report an error if a non-null timeout is null after conversion, and if a timeout overflows. We can probably have parse_time_err() report two dummy pointers for “underflow” and “overflow” so that callers can report errors.
