Hi, I have the following haproxy systemd unit file
Just the defaults.
[Unit]
After=network.target
[Service]
Environment=“CONFIG=/etc/haproxy/haproxy.cfg” “PIDFILE=/run/haproxy.pid”
ExecStartPre=@SBINDIR@/haproxy -f $CONFIG -c -q
ExecStart=@SBINDIR@/haproxy -Ws -f $CONFIG -p $PIDFILE
ExecReload=@SBINDIR@/haproxy -f $CONFIG -c -q
KillMode=mixed
Restart=always
SuccessExitStatus=143
Type=notify
[Install]
WantedBy=multi-user.target
So just the defaults from version 1.8
using systemctl reload haproxy.service works fine and reloads a new process.
However I would like to change the unit file to do
Environment=“CONFIG=/etc/haproxy/haproxy_new.cfg” “PIDFILE=/run/haproxy.pid”
and then reload, after doing a daemon-reload.
However when I check the process running, its always running with the old /etc/haproxy/haproxy.cfg and not with the new /etc/haproxy/haproxy_new.cfg
I understand that this is not conventional, but I’m required to stick to creating a new config file and recreate the unit file and then do a reload.
Can someone help me on how to achieve the above?
