Haproxy has enabled transparent proxy, so we’ve seen two TCP streams:
stream 597: client -> haproxy
stream 598: haproxy -> backend
after normal TLS handshake interfaction between client->haproxy->backend, haproxy sent FIN (#21872) and RST (#21874) to backend directly.
These cause the connection to be interupted, request failed, and client reported:
Exception org.apache.http.NoHttpResponseException ERROR 调用customerHttpClient.execute(request)方法失败,Signals that an I/O exception of some sort has occurred. This class is the general class of exceptions produced by failed or interrupted I/O operations. org.apache.http.NoHttpResponseException: https://xxx:443 failed to respond
And since we don’t see any related packets recieved from client(src client -> dst haproxy), can we say that the haproxy sent the FIN/RST to backend all by itself? Does anybody has any clue why this happened?
haproxy version used:
HA-Proxy version 1.6.13 2017/06/18
BTW, this behavior happened rarely, can not be reproduced manually.
Built with OpenSSL version : OpenSSL 1.0.2g 1 Mar 2016
Running on OpenSSL version : OpenSSL 1.0.2g 1 Mar 2016
Built with PCRE version : 8.38 2015-11-23
Running on PCRE version : 8.38 2015-11-23
root@i-mqfiexf7:~#
And haproxy don’t have any log then, /var/log/haproxy.log was always empty.
Yes, thanks @lukastribus , we just don’t enable syslog by default, so there wasn’t any (helpful) log for this question, and btw, we can hardly (actually never until now) reproduce this problem.
