I spent all day with this issue, no luck.
I have 10 containers on my server, haproxy is sitting in one of them.
I redirected all the :80 and 443 traffic to this haproxy container, and all worked well.
All pem files are placed in the /haproxy/cert folder by cat:
cat /etc/letsencrypt/live/subdomain.domain.tld/fullchain.pem /etc/letsencrypt/live/subdomain.domain.tld/privkey.pem > /etc/haproxy/certs/subdomain.domain.tld
When my SSL certs were freshly created, everything was fine. Now one of them expired, so I tried to renew it. All went well, the pem file is in the right place. No finding from the old pem file.
If I take the new pem file, it validates as new, valid SSL cert.
But when I open my page, I can see the expired SSL next to my URL and the expired cert warning.
I tried:
- replace the certificate
- stop / start / reload
- refresh apache
- reboot all servers / containers
- no old haproxy running in the background
- deleted cert, added new
- checked, no invisible .pem file anywhere in my cert folder
The old expired cert is still visible and can’t get rid of it. Even if I delete with certbot.
EVEN if I delete all cert!!!
As I said, all the other 8 containers work with the SSL, just this one, which I renewed doesn’t.
-vv:
HA-Proxy version 1.8.8-1ubuntu0.10 2020/04/03
TARGET = linux2628
CC = gcc
CFLAGS = -g -O2 -fdebug-prefix-map=/build/haproxy-RAYurj/haproxy-1.8.8=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2
OPTIONS = USE_GETADDRINFO=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_SYSTEMD=1 USE_PCRE=1 USE_PCRE_JIT=1 USE_NS=1
I appreciate any help.
Is that the error?
