I’m using HAProxy as a forward proxy, with a backend consisting of 10 upstream http proxies.
I’m using roundrobin for loadbalancing which works perfectly.
backend pool
timeout queue 30s
timeout server 30s
cookie SERVER_USED insert indirect nocache
server 127.0.0.1:8086 127.0.0.1:8086 verify none cookie c1
server 127.0.0.1:8081 127.0.0.1:8081 verify none cookie c2
I use curl to test this
curl --proxy "http://localhost:3128" https://twitter.com -v --insecure -b SERVER_USED=c2
Persistence is ignored and the cookie is not even ommitted from the request before it is forwarded through the proxy.
