Issue: When a client is keeping long lived connection for gRPC with HAProxy and backend server restarts (goes down then comes back up again), all the subsequent requests fails with 503 RESET_STREAM even after server comes back up.
Client:
h2load http://<HAProxy-IP>:<Port>/fast -c 1 -n 10 --duration 10000
HAproxy Version: 2.0.14
HAProxy Configuration
log 127.0.0.1 local0 info
maxconn 50000
ssl-default-bind-options ssl-min-ver TLSv1.1
maxconn 3000
timeout client 30s
timeout server 100s
option http-use-htx
#option logasap
frontend fe_proxy
bind 10.33.251.152:15004 proto h2
default_backend be_servers
backend be_servers
server 10.20.30.40 10.20.30.40:8081 weight 255 proto h2
HAProxy Logs for failure cases:
[14/Dec/2020:20:23:21.422] fe_proxy be_servers/10.20.30.40 0/0/-1/-1/40007 503 0 - - sC-- 1/1/0/0/3 0/0 "GET /fast HTTP/2.0"
[14/Dec/2020:20:24:01.479] fe_proxy be_servers/10.20.30.40 0/0/-1/-1/40006 503 0 - - sC-- 1/1/0/0/3 0/0 "GET /fast HTTP/2.0"
[14/Dec/2020:20:24:41.543] fe_proxy be_servers/10.20.30.40 0/0/-1/-1/40007 503 0 - - sC-- 1/1/0/0/3 0/0 "GET /fast HTTP/2.0"
When timeout server 100s is set as 30s, it seems to work fine. Is it mandatory to keep timeout server 30s for http/2 case?
Also, after server restarted successfully, it was noticed that HAProxy sends SYN to server, server sends SYN/ACK back and then HAProxy sends RST packet and throws the above log.
Please help with this issue.
