Haproxy with ingress
Hi Team,
I have a confusion/issue with haproxy.
I am implementing haproxy on AKS… I have haproxy deployment, service and configmap files… In configmap I am adding frontend and backend details… now I can access application when I expose my haproxy service as loadbalancer… but I want to use ingress yaml file without installing nginx ingress controller and route the traffic between 2 services in the same namespace… how do I do that?
I have defined a path based routing in my ingress file which is not working currently…
could you please suggest me here
this is my ingress file
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
namespace: haproxy
annotations:
haproxy.org/ssl-redirect: “false”
haproxy.org/path-regex: “true”
haproxy.org/rewrite-target: /$2
spec:
ingressClassName: haproxy
rules:
  • host: raksha.cloud
    http:
    paths:
    • path: /(.*)
      pathType: Prefix
      backend:
      service:
      port:
      number: 80
    • path: /hello-world-two(/|$)(.*)
      pathType: Prefix
      backend:
      service:
      port:
      number: 80
    • path: /(.*)
      pathType: Prefix
      backend:
      service:
      port:
      number: 80
If I define path based routing in my haproxy config it works fine… then in that case what is the use of using ingress yaml file?
I have the same problem. Have you found a solution?
