daggr
January 15, 2020, 6:06pm
1
Recently replaced my HAProxy VM into pfSense HAProxy package instead and that works fine.
I had OpenVPN on a server before but now i want to run it in pfSense as well.
The problem is that i want to run OpenVPN over tcp/443 through HAProxy but i cant get it to work.
Today i’ve set up a frontend which listens to WAN address port 80 (type http /https(offloading)) and redirects to HTTPS.
Then a frontend listening on WAN address port 443 (type http /https(offloading)) with ACLs for different domain names and backends.
I’ve set OpenVPN to listen to TCP/1194 and a backend accordingly.
I’ve tried making a shared frontend but it seems that you can only share the same type (http, tcp and so on).
How should i proceed to configure HAProxy for using tcp/443 to my OpenVPN (on the pfSense machine)?
Thanks!
daggr
January 19, 2020, 11:22am
2
I got it working. Here’s the config if anyone else want to do the same thing.
# Generated on: 2020-01-19 12:06
maxconn 4096
stats socket /tmp/haproxy.socket level admin
uid 80
gid 80
nbproc 1
hard-stop-after 15m
chroot /tmp/haproxy_chroot
ssl-default-bind-options no-sslv3 no-tlsv10
listen HAProxyLocalStats
stats admin if TRUE
stats show-legends
timeout client 5000
timeout server 5000
frontend PROD_HTTP
bind WAN ADDRESS:80 name WAN ADDRESS:80
acl https ssl_fc
timeout client 30000
errorfile 503 /var/etc/haproxy/errorfile_PROD_HTTP_503_MAINT
acl redirect var(txn.txnhost) -m end -i domain.com
http-request redirect code 301 location https://%[hdr(host)]%[path] if redirect
frontend PROD_HTTPS
bind 127.0.0.1:9443 name 127.0.0.1:9443 no-sslv3 no-tlsv10 no-tlsv11 ssl crt-list /var/etc/haproxy/PROD_HTTPS.crt_list
acl https ssl_fc
errorfile 503 /var/etc/haproxy/errorfile_PROD_HTTPS_503_MAINT
acl cloud var(txn.txnhost) -m str -i cloud.domain.com
acl grafana var(txn.txnhost) -m str -i grafana.domain.com
acl aclcrt_PROD_HTTPS var(txn.txnhost) -m reg -i ^cloud\.domain\.com(:([0-9]){1,5})?$
acl aclcrt_PROD_HTTPS var(txn.txnhost) -m reg -i ^grafana\.domain\.com(:([0-9]){1,5})?$
use_backend webserver01_ipvANY if cloud aclcrt_PROD_HTTPS
use_backend webserver02_ipvANY if grafana aclcrt_PROD_HTTPS
frontend TCP_HTTPS
bind WAN ADDRESS:443 name WAN ADDRESS:443
acl http req.ssl_ver gt 0
tcp-request content accept if { req.ssl_ver gt 0 }
use_backend https-term_ipvANY if http
default_backend pfsense_openvpn_tcp_1194_ipvANY
id 100
timeout connect 30000
timeout server 30000
option httpchk OPTIONS /
server webserver01 192.168.37.14:8080 id 101 check inter 1000
id 106
server webserver02 192.168.37.15:3000 id 101 check inter 1000
id 110
server https-term 127.0.0.1:9443 id 101
id 109
server pfsense_openvpn_tcp_1194 127.0.0.1:1194 id 101
