Binding port 443 to both HTTP and TCP
We’ve recently setup HAProxy as one of our application suppliers required it. They supplied a basic configuration which has been working fine. However, we now have another supplier who needs us to accept in traffic on port 443 and forward it to a server on port 6002. So that we wouldn’t have to port forward things we don’t want to, or move servers between networks, I was asked if I could add this into the existing HAProxy setup.
I initially configured another acl which would only trigger if it came from one of the IP ranges that the suppler had specified, but although we could see traffic coming in and being forwarded, they said that the packets coming in made no sense to their application. I then found out that the application is expecting a TCP connection, so I’ve tried adjusting the configuration to separate into 2 different frontends.
The traffic is still not getting through as expected, so I don’t know what else to try at the moment with my limited knowledge of HAProxy. I’ve searched around and it could be an issue where I have port 443 on both an http and tcp frontend?
Below is my current config. I’ve adjusted it to remove sensitive info. I’d appreciate any help that can be given on this issue.
log 127.0.0.1:514 local0 info
pidfile /var/run/haproxy.pid
maxconn 40000
ssl-default-server-ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256
# turn on stats unix socket
retries 7
timeout http-request 50s
timeout queue 2m
timeout connect 50s
timeout client 2m
timeout server 2m
timeout http-keep-alive 50s
timeout check 50s
# statistics admin level depends on the authenticated user
userlist stats-auth
group admin users admin
user admin password password
group readonly users haproxy
user haproxy password password
frontend main
option http-no-delay
default_backend vendor1
acl h_1 path_beg /h/1/
acl server01_down nbsrv(server01) eq 0
use_backend server01 if h_1 !server01_down
frontend main_https
bind *:443 ssl crt /etc/haproxy/certs/our_cert.pem
acl AUTH http_auth(stats-auth)
acl AUTH_ADMIN http_auth_group(stats-auth) admin
stats http-request auth unless AUTH
stats admin if AUTH_ADMIN
stats uri /haproxy?stats
default_backend vendor1_ssl
acl server01_down nbsrv(server01_ssl) eq 0
use_backend server01_ssl if h_1 !server01_down
frontend vendor2_tcp
bind *:443
# Vendor2 access
acl vendor2_prod src -f /etc/haproxy/ipranges/vendor2_prod.subnets
acl vendor2_dev src -f /etc/haproxy/ipranges/vendor2_dev.subnets
use_backend vendor2_tcp if vendor2_prod || vendor2_dev
backend vendor1
option httpchk GET /vendor1web/server/about
cookie h insert
server server01 server01:8080 cookie 1 check weight 100 minconn 3000 maxconn 5000
backend vendor1_ssl
cookie h insert server server01 server01:8443 cookie 1 ssl verify none check weight 100 minconn 3000 maxconn 5000
backend server01
reqrep ^([^\ :]*)\ /h/[^/]+/(.*) \1\ /\2
cookie h insert
cookie h insert
server server01 server01:8443 cookie 1 check ssl verify none
backend vendor2_tcp
option tcpka
option tcp-check
server server02 server02:6002 check weight 100 minconn 3000 maxconn 5000
I know my previous post is old now and I hate bumping up old posts, but, we’re still having issues with this.
We are now at a point where we are getting the frontend matches, but it’s intermittent.
For some reason we are getting connections match the tcp connections from Vendor2 match against the main_https frontend. The connections are not getting to the backend, but is there any way to say ‘if traffic is from x then go to y frontend’?
You cannot configure 2 frontends on port 443, without specifying different IP addresses.
For example, if you have 2 public IP address you CAN do this:
frontend a
 bind 192.168.1.5:443 ssl crt ...
frontend b
 bind 192.168.1.6:443
However you cannot bind to port 443, if any of those bind statements on port 443 doesn’t also specify a dedicated IP address, otherwise your kernel will randomly load-balance between the two.
You can add noreuseport to the global configuration temporarily, to check if haproxy is still able to start. That’s a good indication of whether the port configuration works fine, even without SO_REUSEPORT on the sockets. In this case, your kernel would reject binding to the same port twice, because of this missconfiguration.
So, how could you solve this with just one public IP? Move your SSL terminating frontend somewhere else and use a single frontend on port 443 which decides where the traffic needs to go.
Something like:
frontend 443
 bind :443
 default_backend localhttps
backend localhttps
 server localhost 127.0.0.1:1443 send-proxy
frontend main_https
 bind 127.0.0.1:1443 ssl crt /etc/haproxy/certs/our_cert.pem accept-proxy
The import point is that you only have a single frontend binding to port 443.
Thanks for your help. I’ve just implemented this and we’re now getting the expected results!
