My HAProxy works fine with normal traffic, but when I try to use a traffic generator, captures show packets with the right source / destination / port (80) making it to the front end, but traffic is never sent out of the back end (it is with real / normal traffic). I am using T-Rex Traffic Generator.
I have tried to disable all checks as I’m sure the traffic generator would not pass them, but I can’t seem to figure out what haproxy doesn’t like about the generated traffic - can anyone help?
I have also tried to change mode from http to tcp but this did not make any difference.
ubuntu@ubuntu16:~$ cat /etc/haproxy/haproxy.cfg
frontend localnodes
bind 172.16.200.1:80
default_backend nodes
backend nodes
#option httpchk HEAD / HTTP/1.1\r\nHost:localhost
server trex 172.16.100.100:80
#server web01 172.16.100.101:80
bind *:1936
stats uri /
stats hide-version
stats auth ubuntu:antsle
