When load balancing to two exchange servers Haproxy use its proper address when connecting. This results in a reset on exchange.
I have used different combinations of commands, accept-proxy, send-proxy etc but no success so far. I am beginning to suspect that this is a bug, if not anything is missing in the haproxy installation.
Here is the results of haproxy -vv
HAProxy version 2.7.1-1ppa1~jammy 2022/12/19 - https://haproxy.org/
Status: stable branch - will stop receiving fixes around Q1 2024.
Known bugs: http://www.haproxy.org/bugs/bugs-2.7.1.html
Running on: Linux 5.15.0-58-generic #64-Ubuntu SMP Thu Jan 5 11:43:13 UTC 2023 x86_64
TARGET = linux-glibc
CC = cc
CFLAGS = -O2 -g -O2 -flto=auto -ffat-lto-objects -flto=auto -ffat-lto-objects -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -Wall -Wextra -Wundef -Wdeclaration-after-statement -Wfatal-errors -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wno-string-plus-int -Wno-atomic-alignment
OPTIONS = USE_PCRE2=1 USE_PCRE2_JIT=1 USE_OPENSSL=1 USE_LUA=1 USE_SLZ=1 USE_SYSTEMD=1 USE_OT=1 USE_PROMEX=1
Feature list : +EPOLL -KQUEUE +NETFILTER -PCRE -PCRE_JIT +PCRE2 +PCRE2_JIT +POLL +THREAD -PTHREAD_EMULATION +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -ENGINE +GETADDRINFO +OPENSSL -OPENSSL_WOLFSSL +LUA +ACCEPT4 -CLOSEFROM -ZLIB +SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL -PROCCTL +THREAD_DUMP -EVPORTS +OT -QUIC +PROMEX -MEMORY_PROFILING +SHM_OPEN
Built with multi-threading support (MAX_TGROUPS=16, MAX_THREADS=256, default=2).
Built with OpenSSL version : OpenSSL 3.0.2 15 Mar 2022
Running on OpenSSL version : OpenSSL 3.0.2 15 Mar 2022
Built with Lua version : Lua 5.3.6
Built with OpenTracing support.
Built with PCRE2 version : 10.39 2021-10-29
Built with gcc compiler version 11.3.0
[BWLIM] bwlim-in
[BWLIM] bwlim-out
[FCGI] fcgi-app
[ OT] opentracing
And here is my config at the moment
maxconn 100000
spread-checks 4
timeout connect 5000ms
timeout client 50000ms
timeout server 50000ms
frontend fe_smtp
bind *:25 accept-proxy
default_backend ex_smtp
backend ex_smtp
server smtp1 10.0.0.1:25 check send-proxy
server smtp2 10.0.0.2:25 check send-proxy
