Incoming mails are sent to me by the haproxy IP instead of the remote IP
Hello everyone!
I’m new to haproxy, so I’ll tell you about my situation.
I have a NAT configured in my router on ports 25 and 443 which are sent to my haproxy, which in turn sends it to both my exchange servers.
So far, so good.
The problem I have is that the incoming mails are sent to me by the haproxy IP, instead of the public IP of the remote mail server.
Does anyone know how I should configure haproxy to show me the original IP address of the remote server that sends me the emails?
Thank you very much for any help!
Best regards
Gabriel
my config:
    #  https://mozilla.github.io/server-side-tls/ssl-config-generator/?serve$
    ssl-default-bind-ciphers ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:ECD$
option dontlognull # Do not log connections with no requests
option redispatch # Try another server in case of connection fai$
option contstats # Enable continuous traffic statistics updates
retries 3 # Try to connect up to 3 times in case of fail$
timeout connect 5s # 5 seconds max to connect or to stay in queue
timeout http-keep-alive 10s # 10 second max for the client to post next re$
timeout http-request 10s # 10 seconds max for the client to send a requ$
timeout queue 20s # 20 seconds max queued on load balancer
timeout tarpit 1m # tarpit hold tim
backlog 10000 # Size of SYN backlog queue
balance source #alctl: load balancing algorithm
mode tcp #alctl: protocol analyser
default-server inter 3s rise 2 fall 3 #alctl: default check parameters
frontend front_exch_tcp_https
bind 192.168.20.7:443 name https #alctl: listener$
maxconn 10000 #alctl: connecti$
default_backend back_exch_tcp_https #alctl: default $
server s-mail00 10.10.8.6:443 maxconn 10000 check #alctl: server s$
server s-mail01 10.10.8.7:443 maxconn 10000 check #alctl: server s$
frontend front_exch_tcp_smtp
bind 192.168.20.7:25 name smtp #alctl: listener$
default_backend back_exch_tcp_smtp #alctl: default $
server s-mail00 10.10.8.6:25 maxconn 10000 check #alctl: server s$
server s-mail01 10.10.8.7:25 maxconn 10000 check #alctl: server s$
bind 0.0.0.0:1936
stats hide-version
stats uri /haproxy?stats
stats auth haproxy:sasasaasasasa
The best method with HAProxy is to configure full TPROXY transparency mode - which requires two subnets and the Exchange servers using HAProxy as the default gateway:
At Loadbalancer.org we tend to use a Layer 4 Linux Virtual Server load balancer in Direct Routing mode just for the SMTP ports, as we find its far less likely to break Exchange on customer sites :-).
