I got:
acl host_bacon hdr(host) -i re*****.l*e.
acl host_milkshake hdr(host) -i u.y***.***
use_backend bacon_cluster if host_bacon
^^ alreday.
I want the folder “reports” in host_bacon to go to another server. Only the folder “reports”.
How to make this?
Use path_beg and combine the ACLs in another use_backend statement:
acl folder-reports path_beg /reports/
acl host_bacon hdr(host) -i re*****.l* **e.**
use_backend another_server if host_bacon folder-reports
I get this error:
503 Service Unavailable
It works on /reports. But then i go into other folds in the webserver I get 503 error.
That was an example above. You need to read, understand and have the corresponding backend for that ACL statement.
Share the entire configuration if you have additional questions.
frontend http-in
bind :::80
# Define hosts
acl reports_cluster path_beg /reports/
acl host_bacon hdr(host) -i reports.*****.**
acl host_milkshakes hdr(host) -i u.*****.**
#2
cookie JSESSIONID prefix
server node1 79.***.**.***:88 cookie A check
backend milshake_cluster
server node1 79.***.**.***:89 cookie A check
backend reports_cluster
server node1 92.***.*'6.*19:80 cookie A check
My config.
When i go into reports../reports in my web browser, and go to /reports, I want it to go to the server 92..6.*:80.
The folder reports to go to the IP-address 92.
Have a great day.
use_backend reports_cluster if host_bacon reports_cluster
Not that you are using reports_cluster as name for the backend and as ACL name. That’s highly confusing, please don’t do this.
Hi.
Sorry for confusing you.
I did sorted everyting in my config - and then it worked!
Thank you
But I do got a little problem now.
When I test if the proxy leaks the webserver IP-address, it unfortunately does.
Server IP: 92.6…
How to hide this?
I don’t know what that means, can you elaborate?
The webserver will always see the IP address of haproxy, unless you send X-Forwarded-For header or the PROXY protocol to the backend webserver and that webserver uses it instead of the source IP address of the socket.
I created a phpinfo.php on the web server/IP-address, (the web server that handles specific /reports folder.)
On “SERVER_ADDR” it shows the IP-address of the webserver.
How can I hide it?
Is it possible to make this IP-address to a “192.168.1.x” IP-address for example?
It’s a VPS, virtualization OpenVZ.
This has nothing to do with haproxy at all.
You are in control of the webserver, to not show SERVER_ADDR, just don’t provide any publicly available script showing that variable, especially a phpinfo file.
But again, this is completely unrelated to haproxy.
