Hello guys!
I’m struggling with runtime api information and need some guidance…
In Haproxy’s runtime api documentation we have this information:
Hello guys!
srv_check_state: State of the check (ENABLED/PAUSED/...). The state is actually a mask of values : 0x01 = CHK_ST_INPROGRESS A check is currently running. 0x02 = CHK_ST_CONFIGURED This check is configured and may be enabled. 0x04 = CHK_ST_ENABLED This check is currently administratively enabled. 0x08 = CHK_ST_PAUSED Checks are paused because of maintenance (health only).
https://www.haproxy.com/documentation/hapee/latest/onepage/management/#9.3
But when I run “show servers state” command the api responds with integer numbers, in my case srv_check_state always return one of this four values: 0,6,7 and 14.
I could not find any other documentation explaining these values.
Can someone point me where to look? I’m really confused with this, the same occurs with srv_admin_state values… the docs use this 0x?? numbers but api returns different integers.
