Sir
i have configured Haproxy with ssl-passthrough on centos 7 server as frontend and the same OS has been used for backend also. Haproxy is running fine on backend test page i.e httpd(apache) but it is not running on my php application on backend. Haproxy status showing its Lastchk as L6ok/1mns …my haproxy config below …plz help…
Global
# need to:
# /etc/sysconfig/syslog
################################################################################3
Global settings
log 127.0.0.1 local2
pidfile /var/run/haproxy.pid
maxconn 4000
# turn on stats unix socket
timeout queue 1m
timeout client 1m
timeout server 1m
timeout check 10s
maxconn 3000
frontend https-in
bind *:443
default_backend app
frontend stats
stats uri /stats
stats auth admin:admin
stats refresh 10s
stats admin if { src 127.0.0.1 }
round robin balancing between the various backends
backend app
option ssl-hello-chk
server name of backend host x.x.x.x:443 check
i am using mode tcp i.e Layer 4 but here is status report showing Layer 6
Server
Cur Max Limit Cur Max Limit Cur Max Limit Total LbTot Last In Out Req Resp Req Conn Resp Retr Redis Status LastChk Wght Act Bck Chk Dwn Dwntme Thrtle
server 0 0 - 0 4 0 3 - 18 18 1m34s 10784 194855 0 0 0 0 0 24m23s UP L6OK in 23ms 1 Y - 0 0 0s -
Backend 0 0 0 4 0 3 300 18 18 1m34s 10784 194855 0 0 0 0 0 0 24m23s UP
thanks in advance
