funex
November 15, 2023, 3:12pm
1
I have a problem with the stats on my second backend, first i have this error “Layer7 invalid response: TCPCHK got an empty response at step 2” follow by “socket error”
My configuration file :
log /var/log/haproxy local5 debug
bind :9000
stats show-node
stats hide-version
stats realm HAproxy-ldap-pprime
stats uri /stats
stats refresh 1m
stats auth infra:<%=@passwd_haproxy_stats%>
frontend example_front
bind :389
bind :636
use_backend example1_back if { dst_port 389 }
use_backend example2_back if { dst_port 636 }
option ldap-check
server example1 <%=@ldap_ip%>:389 check
server example2 <%=@ldapbis_ip%>:389 check
option ldap-check
server example1 <%=@ldap_ip%>:636 check
server example2 <%=@ldapbis_ip%>:636 check
I don’t understand why the fisrt work but not the second ?
Thanks for the help.
kali83
November 15, 2023, 8:09pm
2
i have a similar setup to yours.
I used two listens with the configurations i needed.
Bye
funex
November 16, 2023, 7:33am
3
thanks, i’m new in haproxy can you post an example of your config, please ?
thanks a lot.
kali83
November 16, 2023, 11:54am
4
this is the configuration file
maxconn 200
timeout connect 10000
timeout client 120000
timeout server 120000
timeout client-fin 120000
timeout tunnel 3600000
listen Stats
bind :1936
fullconn 200
stats hide-version
stats show-node
stats show-legends
stats uri /
stats auth your_user:your_pwd
listen Ldap
maxconn 100
bind *:389
fullconn 100
option tcpka
server SRV_LDAP_01 ip_server01:389 check maxconn 50 weight 1 fall 1 rise 3
server SRV_LDAP_02 ip_server02:389 check maxconn 50 weight 1 fall 1 rise 3
listen Ldaps
maxconn 100
bind *:636
fullconn 100
option tcpka
server SRV_LDAPS_01 ip_server01:636 check maxconn 50 weight 1 fall 1 rise 3
server SRV_LDAPS_02 ip_server02:636 check maxconn 50 weight 1 fall 1 rise 3
You can insert N servers in each listen.
The default mode is http (you look defaults), but you can specify the mode in each list.
You can check multiple ports in each list
You can balance APIs like DB clusters etc.
Bye
kali83
November 16, 2023, 12:11pm
6
Let me know if everything works…
Bye
