Problems with enabling stats / debian 12
how to enable stats, they don’t post the full haproxy.cfg on “HAProxy version 2.6.12-1+deb12u2” on the Internet
haproxy.cfg:
stats socket /run/haproxy/haproxy.sock
listen stats 0.0.0.0:9000 #Listen on all IP’s on port 9000
balance
timeout client 5000
timeout connect 4000
timeout server 30000
#This is the virtual URL to access the stats page
stats uri /haproxy_stats
#Authentication realm. This can be set to anything. Escape space characters with a backslash.
#The user/pass you want to use. Change this password!
stats auth admin:passwordhere
#This allows you to take down and bring up back end servers.
#This will produce an error on older versions of HAProxy.
stats admin if TRUE
haproxy -c -f /etc/haproxy/haproxy.cfg
[NOTICE] (1554) : haproxy version is 2.6.12-1+deb12u2
[NOTICE] (1554) : path to executable is /usr/sbin/haproxy
[ALERT] (1554) : config : parsing [/etc/haproxy/haproxy.cfg:36] : please use the ‘bind’ keyword for listening addresses.
[ALERT] (1554) : config : parsing [/etc/haproxy/haproxy.cfg:37] : ‘listen’ or ‘defaults’ expected.
[ALERT] (1554) : config : parsing [/etc/haproxy/haproxy.cfg:38] : ‘listen’ or ‘defaults’ expected.
[ALERT] (1554) : config : parsing [/etc/haproxy/haproxy.cfg:39] : ‘listen’ or ‘defaults’ expected.
[ALERT] (1554) : config : parsing [/etc/haproxy/haproxy.cfg:40] : ‘listen’ or ‘defaults’ expected.
[ALERT] (1554) : config : parsing [/etc/haproxy/haproxy.cfg:41] : ‘listen’ or ‘defaults’ expected.
[ALERT] (1554) : config : parsing [/etc/haproxy/haproxy.cfg:43] : ‘listen’ or ‘defaults’ expected.
[ALERT] (1554) : config : parsing [/etc/haproxy/haproxy.cfg:45] : ‘listen’ or ‘defaults’ expected.
[ALERT] (1554) : config : parsing [/etc/haproxy/haproxy.cfg:47] : ‘listen’ or ‘defaults’ expected.
[ALERT] (1554) : config : parsing [/etc/haproxy/haproxy.cfg:50] : ‘listen’ or ‘defaults’ expected.
[ALERT] (1554) : config : parsing [/etc/haproxy/haproxy.cfg:50]: Missing LF on last line, file might have been truncated at position 24.
[ALERT] (1554) : config : Error(s) found in configuration file : /etc/haproxy/haproxy.cfg
[ALERT] (1554) : config : Fatal errors found in configuration.
You are having an issue here: you need a new line after the proxy name, and use “bind” keyword to declare the listening address of the proxy, like so:
bind 0.0.0.0:9000 #Listen on all IP’s on port 9000
balance
timeout client 5000
stats admin if TRUE
