Hi people,
I know it’s almost time to celebrate the new year’s eve
but I’m having issues with the stats socket.
After upgrading Haproxy from 2.0.22 to 2.0.26 suddenly the stats are not available.
The cluster in question is made by 2 nodes. I updated only the passive one to version 2.0.26.
The one with version 2.0.22 is still exposing statistics, the other one doesn’t.
Here is the configuration, same for both of them:
log 127.0.0.1:514 local0
master-worker
nbproc 1
nbthread 2
cpu-map auto:1/1-2 0-1
maxconn 100000
stats socket /run/haproxy/admin.sock user haproxy group haproxy mode 660 level admin
stats timeout 2m
description Bilanciatore ambiente prod
tune.ssl.cachesize 1000000
ssl-default-server-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384
maxconn 100000
no option http-use-htx
timeout client 50s
timeout server 50s
errorfile 502 /etc/haproxy/errors/502.custom.http
errorfile 503 /etc/haproxy/errors/503.custom.http
frontend admin-statistics-frontend
bind :9099
stats uri /
stats auth stats:stats
stats show-node
stats show-legends
stats show-desc
stats refresh 300s
stats admin if TRUE
Hope anyone can help me
Thank you in advance.
