I have a multi-file haproxy configuration that looks something like this:
Global config file:
# used for newer reload mechanism
maxconn 2000
Example redis listener file:
listen redis
bind localhost:6379
server redis001 <internal_redis_host>:6379 check
I am running haproxy using the -f with a path to the folder containing the configuration files.
For some reason, when I query my stats, HAproxy is reporting 0 bytes in/out for my redis backend, even though I am confident that data is flowing through this listener. Other listeners (for example, my PostgreSQL listener), are reporting ok. Any ideas?
