we are using HAProxy running on a vm. Is it possible to have 2 copies one running as a hot spare in case the other goes down? Feel free to point me to a document on how to configure this if one exists
sheetzdw, I have the same setup using 2 HAP servers in front of web servers, one is active the other passive. If the active is rebooted everything goes to the secondary.
It only works with the hap ip address showing up on the web servers so I lose the real IP address which I have tried several times and never got to work. See config below, not sure it is 100% secure, but works.
log 127.0.0.1 local0 notice
maxconn 4096
# turn on stats unix socket
http-reuse always
timeout check 15s
timeout connect 15s
timeout client 15s
timeout server 15s
bind 192.168.0.53:8080
stats auth admin:server123secret
stats hide-version
stats refresh 30s
stats show-node
stats uri /stats
frontend http-in
option httpclose
option forwardfor except 61.16.4.35
reqadd FRONT_END_HTTP:\ on
ACL
acl is_server1.domain.com hdr_end(host) -i server1.domain.com
acl is_server2.domain.com hdr_end(host) -i server2.domain.com
USE_BACKEND
use_backend server1.domain.com if is_server1.domain.com
use_backend server2.domain.com if is_server2.domain.com
BACKEND_SERVER
server domain 10.5.39.253:80 weight 1 maxconn 50 check
server server2 server2.domain.com:8040 weight 1 maxconn 50 check
